Sponsored by: Real Truck
Speed-o issue
Old Aug 5, 2011 | 10:12 PM
aprice's Avatar
aprice
Speed-o issue
ok i have a 2000 super duty with the 7.3 6 speed 4x4 and having an intermittent issue with my speedometer not working. I have to stop and shut the truck off and restart the truck to get it to work again.
Old Aug 5, 2011 | 10:47 PM
jh818's Avatar
jh818
Check your Vehicle Speed Sensor located on top of your rear differential. May need to replace it.
Old Aug 6, 2011 | 09:06 AM
hotroddsl's Avatar
hotroddsl
Remove the VSS from the top of the rear diff housing and it will most likely have a lot of small iron filings stuck to it (it's a magnet) clean off the filings and reinstall it, the filings are normal wear and should not be any concern, this should fix your problem! Hope this helps!
Jim...& fat Monty
ramrod7373
15
Apr 1, 2013 11:37 AM
jamestown55
Oct 8, 2009 03:06 PM
kjf-250
May 24, 2009 06:36 PM
earnhardtracer38
Feb 7, 2006 12:00 PM
fatbob
19
Jun 22, 2004 02:51 PM
