im subscribing to this too. ive been thinking about one and was trying to decide between the stage 1 and stage 2.
also what happens when you use the improver kit along with the switch that b and m sells as well? (the older $30 switch, not the new $180 one)
i dont always hot rod my truck (actually i hardly ever do) so will the stage 2 still shift at the normal shift points? i dont want it redlining everytime before it shifts...
stage 2 would probably be fun at first,but im sure it would get old real fast in a DD.
use the stage 1 springs.you'll feel the shifts,buts it's not going to clean out the U-joints and jerk you back into the seat every shift.
the shift kit doesn't control when it shifts.the computer handles that.
what the shift kit does is makes its shift quicker,without the factory "driver comfort" slow engagement slush.which is actually just letting the clutch packs slowly press together and slip until they fully compresses.this causes them to ware out sooner than if they just would press together sooner and be done.it also drastically reduces heat when you alter the vale body to have them lockup sooner too.
everything about shift kits are good really.just that going with too much or little springs (whichever way it works.can't remember now) is hard on U-joints cus the shift can be so quick it bangs into gear.good for race tracks,but not what ya want in a DD.if you do it,you'll likely get sick and tired of it eventually and find yourself dropping the pan and valve body again to swap in the more practical street springs.
the inline resister is tricking the computers reading of the electronic shift control solenoid value and thereby allows it to send higher pressure through the valve body.this will make the shifts feel more snappy even at low rpm shifts.this is likely a good idea too,cus im sure the engineers at ford set the stock value for "driver comfort" levels too.
The stage 2 doesnt seem to bad to me but then again its only a video and im a 17 yr old boy. It may get old after awhile though. I can also hear my mom complainin about it the first time she has to drive my truck anywhere. Especially in the rain or snow
Reminds me on when mine was in limp mode running full line pressure. It was fun for a min though... Chirping 2nd with light throttle. Burning the tires through 2nd and chirping 3rd at WOT.
The videos are with the stage 1 springs installed. I dropped the pan and changed it from stage 2-1 yesterday.
On another note I you have to drop the Pam for any reason I found a good way to drinking the pan prior to making a big mess while trying to remove it full...
A$15 drill pump and some plastic line. Feed it down the dipstick tube and voila suck all the fluid out and drop the pan mess free... Suck all out you can, start the truck cycle through the shifter range shut it off and suck te rest of the fluid out. Keep in mind this just drains the pan there is still oil ontop of the valve bodies.
How can I tell if my transmission is in limp mode? Cause changing springs and removing/replacing the jumper didn't seem to make a difference and it seems way harder then the punisher valve body
....Pull the codes and see , but the shift kit is going what it was meant to do , the holes that you drilled were for the stage 2 kit , you may need to get a new plate and drill it to the stage 1 , it also soulds like theres something loose in your drive train.....
It has new ujoints and I changed the rear diff fluid at the same time. I did have to use a torch to heat up the rearend to get the plug out tho... Could that have messed the vss sensor? My speedometer is fine so I'm thinking the vss is still ok...
The shift kit don't specify different holes in the plate for the stage 1 or stage 2 just the different springs.
The OD still works I hit the button yesterday and it jumped 500rpm.
In the valve body there was a broken spring that I replaced which the ones in the shift kit.
Could there be something in the accumulator body?
I'm thinking I should have noticed a dofference between the stage 1 and stage 2 springs.... Or the resistor being in/out. It all feels the same to me
