Wipers only work on high and low "constant" speed functions, and also when I use the washer system, and when I turn either of them off they'll just stop at a random place in the windshield, then I have to mess with them to get to bottom.
At the top of the page click the one that's in red that says tech info. In the electrical section there is info that might solve your problem,i was having basically the same problem and it fixed it and it only took about ten minutes and didn't cost me a dime. It was the contacts underneath the black plastic cover of the wiper motor. They just needed cleaned and bent out alittle. Work great now.
looked it up and cleaned the contacts, the copper plate, and bent the contacts out and now it works perfectly fine now! thanks for the info!
