CMP- Ful pump
Old Aug 3, 2011 | 05:23 PM
belas's Avatar
belas
CMP- Ful pump
I'm having problems with 2000 f350 7.3. Had cam sensor code on. Takes truck about 10-15 secondsto start. Once warm, it goes until 2nd gear and chokes out and dies. What could it be, or could it be a couple of things.
Old Aug 3, 2011 | 06:26 PM
CSIPSD's Avatar
CSIPSD
Little lost here...
Did you replace the Cam sensor?
Have you checked the oil level?
Have you checked the glow plug relay?
You say once warm it goes into 2nd and dies? By itself or when you are driving it down the road?
Have you checked the fuel pressure?
Old Aug 3, 2011 | 09:34 PM
belas's Avatar
belas
I have not changed the cam sensor, but the code comes up. Due for an oil change, glow plug relay is about 3 months old, same with the glow plugs (all 8), truck USE to die when driving, now it has really rough idle and dies when applying throttle. Suppose to take it in this Monday to my mech. and he's doing a pressure test and so forth, "said it was the fuel pump over the phone". I have been reading up on these sort of issues, and alot of individuals have stated that a new pump didn't fix the problem. Also, now that you mention it. It has been leaving oil or fuel spots in the driveway.
Old Aug 3, 2011 | 09:41 PM
BigAlsPSD's Avatar
BigAlsPSD
I would lean towards clogged screens in the mixing chamber in the tank, good time for the Hutch mod. Welcome to guzzle's In-tank Hutch Mod Web Page
Old Aug 3, 2011 | 09:50 PM
CSIPSD's Avatar
CSIPSD
Kinda sounds like a fuel pressure issue...
Old Aug 3, 2011 | 10:20 PM
belas's Avatar
belas
So, what do I do about a fuel pressure "issue"?
Old Aug 3, 2011 | 10:52 PM
BigAlsPSD's Avatar
BigAlsPSD
Determine if you have a fuel pressure issue first, buy a gauge that will go to 100 PSI and hook it to the fuel bowl.
oldgameandfishdiesel
Nov 23, 2010 02:52 PM
kunkle77
Apr 7, 2010 02:39 PM
deano70
Jun 14, 2006 12:02 AM
Ken aka Savage
Sep 15, 2004 02:01 PM
okiepacker
Sep 10, 2003 10:54 PM
