Help with I-6 engine I.D.
Old Aug 3, 2011 | 04:57 PM
wagonerkl's Avatar
wagonerkl
One of my neighbors has what he thinks is an old Ford 300 I-6 sitting in his garage for sale. It was supposedly a rebuilt engine that never got installed and just sat in the barn under a tarp. He thinks it is for a Big truck.
It doesn't look like a 300 to me at all. The oil filter (canister type) is on the right side (opposite to any 300 I-6 I have seen). It does have a gear driven timing. The casting number C2TE-6015-A. Anybody got an idea?
Thank you.
Old Aug 3, 2011 | 05:29 PM
SuperSabre's Avatar
SuperSabre
The C2 casting number you quote is from 1962. I'm not sure if the same casting number might have used in subsequent years but I think probably not. I have been wrong before (lots). I just looked up the history of the Ford 300 c.i. engine online and it said the engine wasn't introduced until 1964. You already didn't think it was a 300 - here's another reason.
Old Aug 3, 2011 | 07:03 PM
Broomfieldbum's Avatar
Broomfieldbum
The easiest way to tell the difference between a 223/262 and a 240/300 is the location of the intake & exhaust manifolds. 223/262 have them on the left side of the engine, and the 240/300 have them on the right side. (As seen from the drivers seat.)
Old Aug 4, 2011 | 12:29 AM
wagonerkl's Avatar
wagonerkl
Thanks, that got me going in the right direction.
It appears to be a 262 truck engine. I have no need of one but if someone else does, it is here in Sedro-Woolley, Washington. Send me a PM and I will be happy to act as a go-between.
Old Aug 5, 2011 | 09:12 PM
jhooch's Avatar
jhooch
My 62 Uni has a 262 with a hole in the number one piston. How much is he asking? Does it still turn over? Hopefully it was stored properly.
Old Aug 7, 2011 | 01:08 PM
wagonerkl's Avatar
wagonerkl
Sent you a PM with the CL link.
Keith
Old Aug 8, 2011 | 01:13 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
240 & 300 I-6's introduced in 1965 (1965 model year began September 1964).
223 = 1954/64 / 262 = 1961/64.
1954/59 223: The valve cover attaches to the head with two studs that poke thru the cover.
1960/64 223: The valve cover is retained to the head with 8 bolts.
Old Aug 8, 2011 | 11:05 PM
wagonerkl's Avatar
wagonerkl
Thanks Bill and glad to see you back on-line. I hope you enjoyed our little town and your drive over the mountains.
Keith
Old Aug 9, 2011 | 02:29 AM
NumberDummy
Keith, you were spot on about the wildlife turnouts. The first one we came to had a herd of elk grazing in a meadow.
The Ant
May 15, 2010 07:19 PM
BlueOvalBud
Dec 21, 2006 11:18 AM
jdl123
Dec 12, 2006 06:17 PM
brianwbo
Mar 1, 2002 12:24 PM
