AC Stopped
Old Aug 3, 2011 | 04:41 PM
ssolid's Avatar
ssolid
AC Stopped
JUst got back on a trip from TN to WI, back to TN...AC ran the whole time as it was super hot up there as it is down here.
Wife got into the Ex this morning to take it into town and the front air does not blow at all so conversly the back air blows but is not cold.
Just did a search and there is not much on AC issues.
I will be checking fuses when I get home...Any other suggestions/recommendations?
Thank You,
Steve
2000 Ex 5.4L just rolled 269k
Old Aug 3, 2011 | 06:55 PM
jdadamsjr's Avatar
jdadamsjr
Is your ac controls all dark ? no lights whatsoever ?
this has happened to some before and to me about 4 years ago...
some say turn the lites on and off a few times....
I swapped fuses (MOST of them) just to make sure and apparently it was a flaky fuse because it hasn't happened since
good luck and make sure you know who u are talking to when u say it's hot
110+ here today
Old Aug 3, 2011 | 07:20 PM
Forest's Avatar
Forest
Turn OFF headlights, count to 10, turn ON headlights.
If that does not work, then turn off truck and lock with remote. This stops accessory computer. Then unlock, get in, and turn on engine. Should work now.
Old Aug 3, 2011 | 10:26 PM
ssolid's Avatar
ssolid
AC seems fine.... Front blower does not work hot or cold... Any thoughts?
Relays and fuses all check out.
Old Aug 3, 2011 | 10:58 PM
Immortal_Ben's Avatar
Immortal_Ben
I know it's off topic, but lol@ anything below 130 degrees being called "hot". Just poking a little fun, cause I do know that things such as hot and cold are relative. To the open, I can sympathize, cause the after has gone out in the 2011 F350 I'm driving. Hope you get it fixed soon.
mowin
Aug 3, 2019 06:09 AM
buddy357
Mar 7, 2011 08:24 AM
maistroyoda
Mar 4, 2011 10:56 AM
bigtimebubba
May 23, 2009 10:25 PM
shaper
2004 - 2008 F150
May 24, 2005 05:29 PM
