Sponsored by: Auxito
99 steering wheel shimmy while braking
Old Aug 3, 2011 | 02:50 PM
DanK5's Avatar
DanK5
99 F 150 2 wd. I have developed a steering wheel shimmy when I brake at higher speeds. It does not feel like it's coming from the peddle but up through the steering wheel. It will only shimmy when braking. If I severly down shift (manual tranny) at higher speeds it will not shimmy. I have been told to inspect the drag link and the tierods.
The front brakes were replaced last year sometime I think it was I had the OEM Made In Canada rotors turned and put on ceramic pads from Auto Zone. All was good until a couple of months ago. Thoughts? Warped rotors, tie rod or draglink?
Old Aug 3, 2011 | 04:13 PM
projectSHO89's Avatar
projectSHO89
Warped rotors, usually.
Old Aug 3, 2011 | 06:34 PM
galaxie641's Avatar
galaxie641
Yep that's what mine did when the rotors warped. if Tie rods and/or drag link are bad you should have slop in the steering, be very noticeable when parked. It would also be sloppy/wondering when driving down the road.
Old Aug 4, 2011 | 11:18 AM
DanK5's Avatar
DanK5
Yea I was afraid of that but I don't know if I'm convinced. With it on the ground I checked linkage last night with a pry bar and twisted everything and it all seems tight. The crazy thing is that it just doesn't feel like its in the peddle. If I let go of the steering wheel while braking you can see it shimmy back and forth about a 1/2" but you don't feel hardly anything in the peddle. Steering feels tight going down the road. This is inconsistant with my experience with warped rotors.
Old Aug 4, 2011 | 12:42 PM
projectSHO89
...then get a run-out gauge and measure the rotors for trueness (or lack thereof).
Old Aug 4, 2011 | 10:43 PM
steve(ill)'s Avatar
steve(ill)
"it only does it when i touch the brakes" = rotors
Rob_82
Mar 25, 2015 11:34 PM
amkkba
Feb 6, 2010 08:00 PM
gijoe985
1997 - 2003 F150
Jul 1, 2008 11:02 AM
tarheeldad
Jun 17, 2005 07:24 PM
db3812
2004 - 2008 F150
Feb 8, 2005 07:11 PM
