What makes you think yours is bad? Perhaps you are doing a Mass Air swap?
NAPA and other part stores carry replacement PCMs. I suggest to stay away from the so-called rebuilt units from Cardone, but that is getting tougher all the time. Standard Motor Products does a very good job with their rebuilts.
Are you sure you have an E4OD Transmission?
I would think it more likely you have an 4R70W Transmission.
What is your Transmission code on the door post?
If you have an E4OD then it will be very hard to find a PCM for it.
I had to replace the harness on my 92 F150, I found a 95 f-150 302 mass air truck for almost nothing. I did not know at the time that the 95 truck had the 4r70w trans. If I can find a PCM for the E4OD in 95 I can make it work. Thanks
