Starts and Dies
Pre-Power Stroke Diesel (7.3L IDI & 6.9L) - Ford Truck Enthusiasts Forums Here is a link to the page for your engine, probably better to ask there.
However what you describe would seem like a case of air intrusion. Most common cause is leaking fuel injector return lines but maybe that is what you replaced.
You should also check that the rubber sealing rings in the pipe from the filter to the injector pump are good and also between the lift pump and the filter. Make sure the filter is good and that there are no leaks from it.
paliminolady
06-01-2013 07:57 PM
lmnr0026
11-25-2008 11:01 AM
