filter problem
Old Jan 30, 2010 | 02:29 PM
dieselman77's Avatar
dieselman77
filter problem
i have a 1991 f250,7.3. i changed the fuel filter and was told if i fill the new with fuel it should prime it and i'm good to go.well i did that and now i have no fuel going to the filter.need some input!thanx
Old Jan 30, 2010 | 02:42 PM
Lazy K's Avatar
Lazy K
Pre-Power Stroke Diesel (7.3L IDI & 6.9L) - Ford Truck Enthusiasts Forums This is a link to a great page here for the IDI diesels.
However, when changing the filter it is a good idea to fill the new filter with Diesel Kleen or similar, gets the system primed quicker and helps clean the injection system.
With the new filter fitted you will still need to bleed any air out. Depress the core in the shraeder valve at the filter head and crank the engine untill solid fuel comes out with no air. Then crank again to bleed air out of the injector pump. Sometimes helps to crack open a pipe nut at one of the injectors while cranking. Once the air is out the engine will start.
Do not crank on the starter for more than about 20secs at a time and allow about 2min between cranks for the starter to cool.
Old Jan 30, 2010 | 02:52 PM
dieselman77
i've done all that you said but the problem is i'm not getting fuel to the filter.
Old Jan 30, 2010 | 03:00 PM
Lazy K's Avatar
Lazy K
The fuel system on these trucks is fairly simple. How much fuel have you got in the tank? Sometimes the end of the fuel pickup tube can break off or crack and the pump can`t get fuel when the tank is below 1/4 full.
The fuel lift pump is a mechanical one at the front of the engine so needs the pipe work to be good from there back to the tank or it is possible the lift pump has failed.
Old Jan 30, 2010 | 03:06 PM
dieselman77
i had the truck running earlier today.i drive it everyday.it was fine till i changed the filter.it has 3/4 of a tank of fuel in it.it's really cold where i'm at and was told the fuel may have gummed up.but like i said,it was running earlier.
Old Jan 30, 2010 | 03:22 PM
Lazy K's Avatar
Lazy K
Good point on the fuel, it may have gelled. Might want to add some anti-gel to the fuel in extreme cold.
Old Jan 30, 2010 | 03:43 PM
dieselman77
yeah so i plugged it in about an hour ago and gonna wait awhile and see what happens.
Old Jan 30, 2010 | 04:25 PM
quicklook2's Avatar
quicklook2
check the fuel shut off switch.
Old Jan 30, 2010 | 07:56 PM
dieselman77
thanx everyone for your reply's.i plugged it in for about 2 hours and it started right up.good to know i didnt screw anything up.
