INTERCOOLED!
Old Aug 8, 2011 | 03:29 PM
  #31
MHammer21's Avatar
MHammer21
Originally Posted by RÖENTGEEP
Mike, maybe this helps you is my IC installation thread.
https://www.ford-trucks.com/forums/9...installed.html
Hi Guys,
Just wondering if there would be a huge loss in cooling if I went with a 7.3 cooler vs the 6.0 cooler? Is the install easier with one than another or are parts easier to find/cheaper?
Thanks,
Old Aug 8, 2011 | 03:40 PM
  #32
427 fordman's Avatar
427 fordman
Hey Mike, the 7.3 would be just fine, its a little smaller, thus maybe a little less cooling, probably less than 50* difference. Either one would be good for sure. The 7.3 may be a little easier if a guy uses an aftermarket trans cooler as there would be a little more room, but trans cooler will fit with the 6.0 too.
Old Aug 8, 2011 | 04:34 PM
  #33
wildstang's Avatar
wildstang
VT Chapter Ldr
Supposedly it flows a little better so less boost loss but the plastic tanks don't like extreme boost pressure, maybe 45+ psi. Some 7.3 coolers. Have aluminum tanks and some have plastic.
Old Aug 8, 2011 | 05:02 PM
  #34
MHammer21's Avatar
MHammer21
the 7.3 flows better or the 6.0. So I would want to make sure I get an aluminum tank if I go 7.3.
Old Aug 8, 2011 | 05:17 PM
  #35
Brown Falcon's Avatar
Brown Falcon
The 6.0 flows better. You can tell by the pics that it's taller and thicker. So it'll cool better and flow better, but all the 6.0 coolers have plastic tanks.
Old Aug 8, 2011 | 05:58 PM
  #36
wildstang's Avatar
wildstang
VT Chapter Ldr
I'm just going off bad memory on the psi Max with plastic tanks, could be more but if your pushing that much you would probably have a lot of money tied up in it anyways
Old Aug 8, 2011 | 09:35 PM
  #37
Awitte58's Avatar
Awitte58
If you were to run the larger 6.0 cooler...would you still be able to sneak in a aftermarket trans cooler?
Old Aug 8, 2011 | 10:34 PM
  #38
Brown Falcon
Just remember that Neal is using a 6.0 intercooler with his modded H2E and dynoed over 500hp recently... so I think they're plenty stout!
Old Aug 9, 2011 | 06:13 AM
  #39
427 fordman
I've got the 6.0 IC and the trucool trans cooler in mine. Tight, but they fit. I think you can even get the 6.0 trans cooler in there with the 6.0 IC, but it would be REAL tight.
Old Aug 9, 2011 | 08:15 AM
  #40
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Arrow
Same here: 6.0 IC and Tru-Cool Max in mine, they fit nice. And agree that the 6.0 IC and 6.0 transcooler could fit.
Old Aug 9, 2011 | 08:27 AM
  #41
97XLT4X4's Avatar
97XLT4X4
is $150 a good price for a 6.0 IC?
and looks good!
Old Aug 9, 2011 | 10:25 AM
  #42
wildstang's Avatar
wildstang
VT Chapter Ldr
Sounds like a decent price.
Old Aug 9, 2011 | 10:46 AM
  #43
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Lightbulb
Yeap 120-150 good price.
75kona
All Things Towing
Sep 3, 2018 03:45 PM
jayro88
Aug 2, 2014 07:06 PM
fordpride
88
Nov 11, 2013 09:32 AM
7.3 Rocket
Mar 21, 2010 11:32 AM
weekendwarriorfsw32
Apr 14, 2008 09:05 AM
