INTERCOOLED!
Old Aug 4, 2011 | 11:22 PM
Talyn's Avatar
Talyn
IC for the win!
Old Aug 5, 2011 | 02:23 PM
wildstang's Avatar
wildstang
VT Chapter Ldr
You use 6.0 pipes also and moddified them? use more then two pipes or get some different length of pipes?
You have a transcooler on it other than the stock one? If so what one and were is it hid?
Old Aug 5, 2011 | 04:52 PM
nateairman's Avatar
nateairman
Looks great! Just spent the last few days doing this to mine. Finished fabbing the pipes today (fingers crossed that they don't leak) and the inlet clamp to the spider is the wrong size!
What part number is the clamp? It seems that I have to order one from Ford or buy one from a list member send me a PM if anyone has one.
Old Aug 5, 2011 | 07:11 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
Are you refering to the new (little wider) V clamp between the turbo and the early 99 Y pipe? if so this is the part #
V BAND clamp retrofit IC: F81Z-8287-DA Motorcraft: YF-2488
Old Aug 5, 2011 | 09:46 PM
fordpride's Avatar
fordpride
Ian could you post a better pic of you IC pipe I will be doing this in a few week and would like a better veiwmof what I will have to do to the pipes
I will give you a call Monday morning. Thanks
Old Aug 6, 2011 | 02:09 AM
1982_f150's Avatar
1982_f150
Might be a dumb question but can you use the pipes off a 99-03 7.3??
Old Aug 6, 2011 | 06:21 AM
427 fordman's Avatar
427 fordman
Yes you can, they are actually the easiest to use, but still take some modifying.
Old Aug 6, 2011 | 08:37 AM
nateairman's Avatar
nateairman
I had two sets lying around. One aluminum the other steel. Ended up adding two and a half inches to both but in different areas. Taking the inner fender out on the passanger side is worth the effort as you have good access to the lower clamp.
Thanks for the part numbers roentgeep. The v clamp on the stock y pipe is too narrow and the ford dealer wasn't any help.
Old Aug 6, 2011 | 09:58 AM
plgebbia's Avatar
plgebbia
Originally Posted by Brown Falcon
How much cooler is it running?
It knocked about 100 degrees off peak egts. (but the pipes are leaking too, so it should cool off more once the leaks are fixed)
I'll try to get you some better pics... I have been real busy, trying to prepare for going out of town Sunday -Wednesday (I am going to a conference monday and tuesday, so I may be hard to get a hold of.... just text me, and I will call you back at lunch break or something.)
I added about 2 1/2 inches to each pipe (about) depending on how the cooler is mounted will determine the length of your pipes.
Old Aug 6, 2011 | 10:02 AM
plgebbia's Avatar
plgebbia
BTW, I used 99-03 7.3L pipes (3 of them) you can just use 3 in exhast pipe if you only have access to 2 intercooler pipes.
Old Aug 6, 2011 | 12:17 PM
wildstang's Avatar
wildstang
VT Chapter Ldr
Need to be careful because some of the early ones were aluminum not steel.
Old Aug 6, 2011 | 07:11 PM
1982_f150's Avatar
1982_f150
Is there an advantage to steel?
Old Aug 6, 2011 | 07:55 PM
  #28
wildstang's Avatar
wildstang
VT Chapter Ldr
Easier to weld when modifing.
Old Aug 8, 2011 | 08:19 AM
  #29
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
You are welcome. I hope it helps you. I bought it from Ed´s
Old Aug 8, 2011 | 08:24 AM
  #30
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
Mike, maybe this helps you is my IC installation thread.
https://www.ford-trucks.com/forums/9...installed.html
