IC INSTALLED.
Old Aug 30, 2010 | 08:44 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
IC INSTALLED.
I just finished the installation of a 6.0 IC, I want to share some pics. I havent check the EGTs yet, but I will, its not my DD is just my tow truck for my TT, maybe on the next vacations
Old Aug 30, 2010 | 08:49 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Some more pics and I changed the front lights too been there
Old Aug 30, 2010 | 08:54 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
I put an insert between the cover and the dipstick to shim it to easy access.
Old Aug 30, 2010 | 09:11 PM
oldbird1965's Avatar
oldbird1965
Very nice install, I'm impressed.
Old Aug 30, 2010 | 09:14 PM
Brians97F250Crew's Avatar
Brians97F250Crew
Looks good... nice job. Is your truck 2wd or 4wd
Old Aug 30, 2010 | 09:50 PM
BIGRED 7.3L's Avatar
BIGRED 7.3L
I see you have an extension of some type on the valve cover where you pour your oil in. Is that factory or did you by that somewhere? Mine is just the cap directly in the valve cover.
Old Aug 30, 2010 | 09:56 PM
plgebbia's Avatar
plgebbia
Looks great!!! Very professional looking!
Now I got to get around to finishing mine......
I like the dipstick shim.
Old Aug 30, 2010 | 10:18 PM
wildstang's Avatar
wildstang
VT Chapter Ldr
Very Nice install looks factory. Did you customize the pipes at all or just use boots to connect them?
Old Aug 30, 2010 | 10:35 PM
Fullcrew7.3's Avatar
Fullcrew7.3
Great job!!!!! Looks a lot better than my install.
Old Aug 30, 2010 | 11:19 PM
jchosler's Avatar
jchosler
Nice, looks like you used the 6.0 pipes. Why is it the hot side has a dent in it? mine does the same thing but mines from a 2000 SD
Old Aug 31, 2010 | 05:50 AM
427 fordman's Avatar
427 fordman
Looks great Jose. You've been busy...
Old Aug 31, 2010 | 07:25 AM
Brown Falcon's Avatar
Brown Falcon
Looks awesome!
Old Aug 31, 2010 | 10:05 AM
superduty4x4's Avatar
superduty4x4
Nicely done. And nice headlights too (see my thread )
The dent in the hot side pipe looks like a factory SD 7.3 pipe (which needs to be dented to clear the power steering pump) flipped around.
Old Aug 31, 2010 | 12:25 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Talking
Thank you my friend.
Thanks, is 2wd
Its from a SD, I bougth at the IH dealer.
Oil Fill Extension (Super Duty style, uses same cap
(Ford) 4C4Z-6783-AA (7.3L, 6” long)
(Ford) 3C3Z-6763-AA (6.0L, longer)
I dont have in hand the IH number.
Thanks too. Yeap its easy to get the dipstick.
I used a SD pipe to the drivers side, and the pipes thats comes with the 6.0 IC from a 2004 to fab the pass side and connect with boots as you see in the pics.
Thanks.
Read the last quote, thats the reason.
Yes I was very busy, I work by myself to DIY, so it takes more time, and I dont have to much free time, just little by little. Thanks
Originally Posted by Brown Falcon
Looks awesome!
Thanks.
Thanks and you are right about the pipe. (Im going to see your thread)
GRACIAS A TODOS for the compliments and comments.
Old Aug 31, 2010 | 12:56 PM
jchosler's Avatar
jchosler
So, tell us more about the performance, notice more turbo lag?
