Sponsored by: Auxito
My engine pinging during take off.
Old Aug 2, 2011 | 07:31 PM
rlay302's Avatar
rlay302
I know my truck is 1996 and I have posted a thread in the correct section.
I hope some can point me in the right direction.
I have a 1996 F-150 V-8 302 with 127,000 miles and here in the last year I here valve pinging every time I fill up with new Ethanol added gas. Now, if I add octane treatment, seafoam or fill up with super unleaded I do here it. Its mainly when I get into it to pass someone or drive up a steep hill. Could there be something wrong with the engine? What about the timing should I increase it or decrease it.
Any idea's will help.
Thanks,
RLAY302
Old Aug 2, 2011 | 11:21 PM
Bluegrass 7's Avatar
Bluegrass 7
I would check the ignition timing with a light to see if it is set on the marks at the crank.
Do this with the link plug out on the distributor cable to TFI so the timing is not influenced by the computer.
Then if you still get pinging be sure the EGR is not leaking.
If ok, you can retard the timing about 2 degree to reduce it.
Even if you hear a sleight amount it won't hurt but don't go to much more or power will begin to suffer noticably.
The problem could be carbon deposits in the combustion chambers.
Good luck.
DoofusOfTheDay
24
Sep 10, 2013 11:40 AM
jmcgardner
Oct 25, 2004 11:01 PM
whoop09
1978 - 1996 Big Bronco
May 18, 2004 09:48 AM
SgtMaj
Mar 11, 2004 05:46 PM
slave2dafords
Dec 10, 2002 11:14 AM
