Alignment?
Old Aug 29, 2011 | 10:28 AM
Hdslider's Avatar
Hdslider
Good for you. dont take no BC from them.
Old Sep 20, 2011 | 10:29 AM
markiemark's Avatar
markiemark
O.K. Service advisor talks to Field Service Rep.and wants my truck back. Ford kept the truck two days and no change. Said they checked the hubs for any issue's. Now according to Field Service guy, wants to install 1 degree casters. Said if that does not work, they would remove and put in 2 degree, so on and so on. Does this sound right. Thanks, Mark
Old Sep 20, 2011 | 04:27 PM
6.7Fan's Avatar
6.7Fan
Just noticed this thread. I had a bad pull to the left. Went round and round with the dealer, alignment shops, my tire shop (where I got the aftermarket tires)....
2 things were done (after a few alignment checks, straightening the steering wheel).
1) The dealer found that my calipers were sticking / seized. They said there was a TSB about it. They replaced the entire front brakes...calipers, rotors, shoes, pads, etc. This freed up the front wheels, but I still had the pull.
2) They finally put a stock set of tires and wheels from another truck on mine and it drove straight as an arrow. It was determined that I had "radial pulls" in multiple tires. Now, mine were aftermarket tires but that could happen anywhere and rotating the tires won't fix it if you have more than one bad tire.
The tire shop ultimately replaced all 4 tires at no charge (and with 11,000 miles on them). After that, the pull was gone and continues to drive straight. Now at 18,000 miles.
Not sure if either of these issues apply to your truck, but wanted to throw it out there.
Old Sep 21, 2011 | 09:09 AM
markiemark's Avatar
markiemark
Thanks for the information 6.7Fan. I will be throwing that out to the service tech as well.
Old Sep 21, 2011 | 01:42 PM
Hdslider's Avatar
Hdslider
Mark. Yes adding more pos caster on rf. will tend to make it pull to left. so that should take care of it. Do you know how much caster is in LF,and RF. before they add any?
Old Sep 21, 2011 | 01:57 PM
markiemark's Avatar
markiemark
No, don't know what degree is in now. All I know is after 2 alignments, new tire, new wheel, and then last week messing with the hubs and still pulls. I hope this does the trick. Down the road when I get larger wheels and tires I hope this does not come back to bite me. Thanks for your input Hdslider, appreciate it. Mark
thendrix
Jan 4, 2017 06:11 AM
Bat-Masterson
Jun 8, 2011 10:28 AM
jamie7375
Mar 5, 2009 05:04 PM
tspivak
Nov 27, 2007 07:21 AM
mikedeason
Nov 21, 2006 11:46 PM
