2001 Navigator Alignment
Old Oct 10, 2007 | 01:34 PM
tspivak's Avatar
tspivak
I just bought new tires and had the truck aligned. The steering wheel tilts to the left when the car goes straight. When I straighten the steering wheel, the car moves right. I brought it back for realignment and it was improved but the wheel still tilts to the left a little. Is this acceptable or is the alignment still off? If it's off, can someone supply me with the specifications as I do have a copy of the last realignment and can compare it.
Old Oct 10, 2007 | 09:42 PM
ubereal2's Avatar
ubereal2
Wink
If you're driving the vehicle on a nice, straight, level road, let go of the steringwheel, does it go straight, or have an immediate pull either way?
If it gose straight, then the steering wheel just wasn't straightened when the alignment was done. That won't effect you're alignment at all, just cosmetics. Vary difficult to get perfect.
Old Oct 11, 2007 | 03:44 AM
cr_expyeb98's Avatar
cr_expyeb98
If the vehicle is not pulling, as mentioned, it is just simply steering wheel alignment. Difficult, maybe, but doable and it is annoying. Take it back to the alignment shop and have them do it again.
Old Oct 11, 2007 | 07:49 AM
tspivak's Avatar
tspivak
Thank you.
Old Oct 11, 2007 | 07:50 AM
tspivak's Avatar
tspivak
Thank you.
Old Nov 24, 2007 | 09:08 PM
geraldweber's Avatar
geraldweber
ubereal correct
I used to align wheels on new Camrys at the factory. If you let go of the wheel while traveling on a flat road surface, and the car tracks straight, the alignment is "probably" ok. While your wheel alignment is done they should attach a jig to your steering wheel that locks it in place. What ever position it is in when they align it is the position it will be in when driving straight.
Old Nov 27, 2007 | 07:21 AM
tspivak's Avatar
tspivak
2001 Navigator alignment
Thanks,
NTB tried 3 times to get the steering wheel straight. They did attach a lock bar to the steering wheel and it still tilted left. I finally took it to a local guy who is known for doing alignments and it's finally straight.
Dezl Newbie
13
Dec 27, 2016 03:19 PM
bradlow
Aerostar
24
Jun 26, 2016 10:36 AM
granny_rocket
Dec 17, 2015 06:03 AM
FordHammer
Aug 5, 2014 04:53 PM
bulldog288
1978 - 1996 Big Bronco
Jul 28, 2003 04:04 PM
