I will be changing the filter next weekend on the wifes Ex for the first time in 3 months and kind of anxcise to see what that one will look like. Also will be putting the kit on my F350 next week along with a bunch of other mods.
Marv,
If the filter is mounted low like yours is, do you loose alot of fluid when changing the filter?
I would think a valve on each side of the base would eliminate this.
What do you think.
I've got mine mounted low behind the left front wheel well, put gas ball valves on both side of filter head & only lose what's in the filter when I change it.
Gas ball valves. Brass I presume.
Thanks for the info.
Marv,
What do you think.
What I think is that someday I'm going to get around to adding the valves I should have originally installed!
Currently, I just use a couple of "hose pinchers" while I change the filter. It works, but isn't quite as neat.
Signs of potassium and/or sodium point toward coolant in the oil.
In this case I think ignorance may truly be bliss, I'm going top run a 500 mile oil and coolant filter change. I'll cut them open and inspect and if everything is clean just forget about it. With 340K+ I would rather not have blackstone tell me I am driving a ticking time bomb.
Originally Posted by Franko72
Uh Oh!
I also have my fingers crossed for you Steve.
Here is what my first filter looked like last month. Just coolant and a little sludge. The actual filter was just wet and rust colored. I hope neither one of us is in for a suprise.
How old was that filter Frank?
Originally Posted by miller_feed
I wonder if you didn't have the coolant filter on the system, you would have seen the oil earlier?
Well, if nothing else, the filter was sure doing its job. Hope it's just the o-rings.
I think I would have seen it earlier with out the filter, but it is hard to say. Evans coolant is pretty dark to start with.
I got rid of the Evans and am now running CAT ELC. The Evans was nice, 0 pressure meant no issue with sealing the thermostat housing, Not the case now.
As we speak I am running my "Evans prepped" rad cap with a hole in it because when I put my new cap on the billet t stat housing started leaking slightly more than a weep. I picked up a tube of "Form a gasket" last night so I can cure that tomorrow morning.
The cooler reseal went easy as described. I called Bob ( guzzle) to get the part numbers. The local dealership tried to gouge me for $180+ for the o rings and gaskets, I asked if they would price match and showed them a printout from Ed's site and got them for ten dollars more than he sells them. I would have loved to bought from Bob, Ed or Clay but I was in a hurry.
Pulling and installing the cooler would have been a PITA without a pneumatic ratchet for the 2 front bolts, R&R and re-ring took maybe 45 min with a good cleaning.
after seeing the condition of the cooler o-rings I think next payday I am going to throw a set of o-rings under the injectors....
With a messy filter like that, Does the coolant look like that as well in the decas tank? In other words, would you have noticed the leak as fast without the filter? Does the filter catch all the oil? Almost need a see through glass type filter, That would be cool. Quick visual.
Marv,
What do you think.
