Coolant filter install.
Old Jul 1, 2015 | 07:37 AM
ramsay's Avatar
ramsay
After doing the oil cooler twice (in four years) I smartened up and installed a coolant filter. It would have been cheaper and faster to have bought a kit but I like how this looks. Almost factory...
Filter base.
Filter inlet.
Filter return line.
Old Jul 1, 2015 | 07:50 AM
WatsonR's Avatar
WatsonR
did you do a coolant flush with chemicals before the oil cooler (s)??
Old Jul 1, 2015 | 08:27 AM
jsm180's Avatar
jsm180
Nice install but unfortunately for us the best coolant filter for the 6.0 is still the oil cooler. A clean system and regular maintenance is key.
Old Jul 1, 2015 | 12:15 PM
73fan's Avatar
73fan
Where do you get the base for that? eBay? I think something like that might be a good investment on my truck...
Old Jul 1, 2015 | 12:33 PM
silverbullet6oh's Avatar
silverbullet6oh
It doesn't look like a bypass system, or is it?
Old Jul 1, 2015 | 02:59 PM
ramsay's Avatar
ramsay
It's a hybrid. In the summer when the valve to the heater core is closed it goes to the filter only. In the winter it's a bypass unless I close the manual valve, in which case it is isolated from the system completely. If it warms up too slowly in the winter that is what I will most likely do. I was gonna go full flow but there isn't a lot of room for the size of filter that would be required.
Old Jul 1, 2015 | 03:07 PM
ramsay's Avatar
ramsay
WIX BASE 24763
WIX FILTER 24069
Gates 28492 3/4 Inch Hose
all from Amazon.com
2- Mini Ball Valve 1/2" MALE X FEMALE NPT Chrome Plated Brass Body 450 psi M X F and 3- Dorman HVAC Heater Hose Connector - 3/4" Hose x 1/2" Npt x 1-3/4" Long Nipple were from ebay.com.
The rest of the steel pipes and fittings were made from an old 1/2" pipe thread Tee and some wrecking yard 3/4" coolant pipe and hose clamps.
I did the first time. This time I just swapped the cooler.
Old Jul 1, 2015 | 04:33 PM
dannyboy950's Avatar
dannyboy950
While you can find them on e-bay every filter manufactuer also sells the base and filter.
They are useually in a seperate section of their catalog.
Most engines do not come from the factory with a coolant filter not even for the big dogs. It is considered a add-on which most people do add on. Even on the big rigs.
Old Oct 5, 2015 | 01:13 PM
coolfeet's Avatar
coolfeet
I have the E350 van. Any recommendation for the best kit for a van? Dieselite sells a kit but does not come with mounting bracket. I want a complete kit.
Skylucas14
Sep 9, 2021 02:54 PM
rollnhvy77
May 4, 2019 11:19 PM
Mike in Arizona
Apr 18, 2018 07:56 PM
dlibson
Jul 11, 2013 10:30 AM
clem1226
44
Aug 5, 2011 12:04 PM
