2001 F350 SD
Old Aug 1, 2011 | 09:28 PM
Horseforce's Avatar
Horseforce
2001 F350 SD
My brake lights came on, all three lights, tried pulling fuses, didnt seem to effect the lights, key on or off makes no difference. Unplugged the brake pedal switch lights stayed on. Once unplugged tho cannot shift the truck(auto trans). If I plug into a trailer the trailer brake lights stay on as well. Anyone know whats going on? Thanks!!!
Horseforce
Last edited by Horseforce; Aug 1, 2011 at 09:32 PM. Reason: change title to 2001 F350 SD brake light problem
Old Aug 2, 2011 | 06:53 AM
megawatt00's Avatar
megawatt00
Welcome to FTE. If your lights are on and you pulled the fuse and they stayed on then I would have to guess that the wires are shorted and are picking up a feed from elsewhere. I would pull each fuse one at a time until either there are none left in the fuse box or the lights go out then we can tell where they are getting fed from.
Old Aug 2, 2011 | 08:43 AM
Horseforce's Avatar
Horseforce
01 SD Brake light problem
Thank you sir , I will start there!
70runner
Nov 4, 2012 01:27 PM
Cableman
Electrical Systems/Wiring
Oct 22, 2011 08:04 AM
250f4life
Sep 17, 2008 09:15 PM
Centroplex
Jul 6, 2006 04:54 PM
