Hi I have a 1993 Ford f150 single cab XL. I have noticed that under acceleration the engine make a sort of ticking noise, it's hard to explain but I don't think it is a engine knock. My buddies have a 1994 Ford f150 single cab XL and his does the same thing. My other buddy has a 1996 Ford f150 single cab XLT and it does not make that noise. Does anyone know what this is, and can help me fix it?
yes the other 2 guys have the same engine, and mine has 85,000 miles
Hmm... shouldn't have top end noise at 85K unless the engine was severly abused.
I would check your oil pressure at the block with a manual OP guage. They are only $20 and the OP guage you have in your cab is most likely a idiot light (pressure switch that kicks on at 7psi so you don't know real OP).
I would also check your compression in cylinders. I know this doesn't help for this particular diagnostic but between compression and OP it tells you the overall health of your motor.
If your truck had a previous owner that waited a long long time between oil changes carbon build up on the head can block the oil passages starving the engine of oil. Likewise chunks of that carbon can break loose and move to the oil plan blocking the oil pick up screen and starve the engine of oil also. No oil on the top end would cause a lifter/rocker knock... Same problem I had with my 92 years ago.
I already know what it is. I had a 302 in a 93 model that did the same thing. All it is is sticky valves. Im serious. Run two tank fulls of 93 octane through it, and it will be fixed. Maybe even some sea foam. My stepfather is a mechanic of 30 years and thats what he told me. I ran two tank fulls through it and it cleared up. Im telling you, it sounds stupid, but it worked.
I am assuming you have the 300 six by the title of you rpost. If so, my suggestion is check the air injection pipe. It runs along the head, under the upper intake runners. Very common exhaust leak, and most noticable under acceleration. If it is bad, check out psiinc.com and order a new one. new tube with fittings for about $120. Takes about 6 to 12 hours to replace if you have never had the upper intake off before.
Normally top end ticks wont happen only under acceleration. It's most likely an exhaust leak.
these were my thoughts. "ticking" is normally an exhaust leak, or a collapsed lifter. a collapsed lifter would tick all the time, in relation with engine rpm.
