ignition problem please help
Old Jul 31, 2011 | 09:25 PM
Shaun lindmark's Avatar
Shaun lindmark
Hey guys I was about to head home from my camp about a 125 mile trip and went in my truck turned the key to on and put the windows down. Went to turn the key back off and nothing happened, the key spun freely like it wasnt grabbing anything. Turned it all the way back and got it to start. Could not shut truck off though. I thought the ignition was stripped out so i removed it and used a screw driver to turn the gear inside and still nothing. It spins freely and will only grab if you turn it all the way to start it. Thats it. I had to pull the main fuse under the hood to shut it off and just disconnected the batteries. I think its something internally in the colum but not sure. Has anyone had this problem before ? or any other things to look at to try and figure this out.
I apreciate any help guys need to figure this out ASAP
Shaun
Old Aug 1, 2011 | 05:48 AM
tjc transport's Avatar
tjc transport
i ain't rite
you are going to have to pull the column apart. after you get the steering wheel off, pull the blinker switch, and then pull the upper column cover to access the gears behind the key cylinder. you will see the problem once you get down that far into the column.
Old Aug 1, 2011 | 06:04 AM
Shaun lindmark
Ok thank you I will do that today
Old Aug 1, 2011 | 06:10 AM
tjc transport
i ain't rite
once you get down far enough, you will see a rack style gear behind the key cylinder that engages the rod to the ignition switch.
my guess is that that part is bad and the gears are no longer engaging. .
Old Aug 1, 2011 | 06:20 AM
Shaun lindmark
Ok cool I have never ripped one of these apart so I had no idea how they work. Also the dealership should be able to find what ever part I need if I bring it to the correct ? I was thinking it might be easier to go to the junk yard and get a whole new colum do you know if any one out of an obs will work or does it have to be from a diesel ?
Thanks again for all your help
Old Aug 1, 2011 | 06:29 AM
shorebird's Avatar
shorebird
Definitely in the column.
If you find a column in the parts yard be sure to keep the wheel from spinning so as to prevent damage to the clockspring.
It should not matter if it comes out of a gasser or deisel.
Old Aug 1, 2011 | 06:32 AM
fishmanndotcom's Avatar
fishmanndotcom
i recently had this problem in my truck after replacing the worn out column bearings. what happened on mine and what it sounds like on yours is the lower actuator is broken. it is plastic and after 13 years it tends to get brittle. the ignition switch is connected to a plastic rod that connects into a slide within the actual ignition switch. the end of the slide is broke on mine. thankfully it did not break cleanly so if i crank my truck i can tilt my steering wheel all the way down and the actuator will catch and i can shut the truck off.
i think this is what you broke, it should be #26:
http://www.trademotion.com/partlocat...layCatalogid=0
-cutts-
Old Aug 1, 2011 | 07:16 AM
Shaun lindmark
great info guys I love this site, i just need to decide what i should do. get one from a scrap yard or open mine up which could be a big can of worms. I am pretty mechanically good but all those little parts getting taken apart seems easy to mess up lol
Thanks, Shaun
irfreddy
37
Jul 20, 2016 12:53 PM
brc777
1983 - 2012 Ranger & B-Series
Oct 11, 2010 09:04 PM
Barndon
Mar 26, 2010 02:57 PM
DNewton
Sep 20, 2006 08:08 PM
shrug
Jan 13, 2006 06:52 PM
