Need help with axle retaining clips
Old Jul 31, 2011 | 03:20 PM
85bobtail's Avatar
85bobtail
I need to remove axle shafts from Ford 8.8, any tips for removing the "C" clips from end of shafts would be helpful.
Thanks
Old Jul 31, 2011 | 05:06 PM
Archion's Avatar
Archion
Veteran: Marine Corps
If I remember right, you push in hard on the axles and just pull the clips.
Old Jul 31, 2011 | 08:50 PM
pegman's Avatar
pegman
demon chaser
Thanks
a little blood sweat and tears they are a bitch to remove but as simple as moms pie to put back in im thinking there might be a store tool for that i removed mine with a couple screw drivers but like i said it wasnt easy
Old Aug 1, 2011 | 11:09 PM
Wyowanderer's Avatar
Wyowanderer
Thanks
Easy peasy:
Buy yourself a 5/16" six point end wrench and remove the retaining bolt/pin . Remove the crosspin, push in the axles, and the c clips will fall out. Using a six point wrench will likely keep you from stripping the head off the retaining bolt/pin, BTDT.
Install the bolt/pin with locktite so it doesn't fall out and ruin your day, or buy a new one from Ford.
Old Aug 2, 2011 | 05:07 AM
Sport45's Avatar
Sport45
The above poster is correct. But first you have to pull your brake drums and enough of the brake hardware to be able to push the axle in.
Sometimes the retaining bolt breaks and the pin won't come out. When that happened to me I make a trip to the wrecking yard with a couple hundred dollars for a replacement axle.
Old Aug 2, 2011 | 09:47 AM
Wyowanderer
If it breaks (heaven forbid!) you can sometimes drill out the offending piece without destroying the threads. It ain't easy, though-the steel is pretty tough stuff.
Good luck and happy wrenching.
jbvsr
Oct 15, 2014 07:30 PM
Tom D
May 5, 2007 11:02 AM
harem Scarem
Feb 10, 2005 04:22 PM
noslow50
Jan 24, 2005 07:21 AM
noslow50
Jan 24, 2005 04:28 AM
