pickup surge while stopped
Old Jul 31, 2011 | 08:41 AM
4getmenot's Avatar
4getmenot
my first truck, its a 1970 F100, the motor is a 400 auto tran. it surges while stopped.
Old Jul 31, 2011 | 01:56 PM
tmcalavy's Avatar
tmcalavy
Explain surges...idles high? tries to overrun the brakes?
Give it a basic tuneup...points/condensor/plugs&wires, check timing and make sure all the vacuum hoses and connections are good.
Old Jul 31, 2011 | 02:15 PM
4getmenot's Avatar
4getmenot
reply
it tries to overrun the brakes
Old Jul 31, 2011 | 05:17 PM
tmcalavy's Avatar
tmcalavy
idling too high...should run about 550 to 650 at idle in D. how does it run otherwise? If good, reset the curb idle and check the timing. If not good, do a tuneup, timing check and check curb idle...sounds like you have a vacuum leak. are the brakes sound?
EthanWay
24
Jul 25, 2017 03:40 PM
intofire56
Jan 31, 2014 06:01 AM
skeneguy
Nov 2, 2010 01:07 AM
Gorilla1
19
Feb 5, 2007 07:11 PM
CustomCab4x4
May 8, 2002 04:24 PM
