Timing adjustment using vacuum
Old May 7, 2002 | 06:22 AM
CustomCab4x4's Avatar
CustomCab4x4
Old May 8, 2002 | 11:12 AM
skeeze's Avatar
skeeze
Hi everyone, on a 1975 390 I've set the timing at 20 BTDC to get the truck to idle close to smooth.Any less timing and it's rough. Using a vacuum gauge hooked to the intake at highest reading and vacuum is at 20 and timing at 25 BTDC. Any advice? Thanks
Old May 8, 2002 | 04:24 PM
dfisher1's Avatar
dfisher1
Skeese,
There are a few things to consider when answering this.
1. Is the motor stock?
2. Is the factory specified timing chain on it?
3. What's your compression? Does it burn oil?
Does your vehicle start warm OK? Does it ping? If there is no problem with the way it runs, then don't fix it!
20 inches is high, in my opinion. Many say that's OK. I think running around 16 inches is better. Set your timing according to factory and then set your vacuum to about 16 inches. Then enrichen your idle circuit to get a nice idle. I start my idles screws at 1-1/2 turns and enrichen each equally until I get the idle I want. If the idle is too high at 1-1/2 turns then close your throttle down to get the right idle. If this happens remeasure your vacuum and report back. I'm curious to see what you end up with.
KingFisher
