Timing Vacuum
Old Jan 30, 2007 | 09:17 PM
Gorilla1's Avatar
Gorilla1
Timing Vacuum
Should have included this in the last one, but I bought me a fancy (not really) vacuum guage for the truck to check the timing with. Bro in law is a decent meckanick and said timing can be checked via vacuum. So I done bought me the guage. It has a nice green zone that says the engine is good, but the range is between 17 and 22Hg. I was hoping to tighten it up even closer but don't know where to go to with it. Any ideas on where I should shoot for when adjusting the timing using the vacuum? By the by, my timing light is ghetto and my balancer is hard to read...
Thanks again!
Rich
Old Jan 30, 2007 | 09:26 PM
George Frasier's Avatar
George Frasier
I used to clean the timing marks off REAL GOOD and use a thin stripe of white finger nail polish on the wheel - where you want it to be. It usually stays and is visible for a couple years. Sometimes, it's easier to crawl under the truck to do this - it saves trying do reach around hoses, wiring and such - and it'll be right in front of your nose.
Old Jan 30, 2007 | 10:13 PM
tractoman's Avatar
tractoman
Vacuum guage will check vacuum not timing. An engine is a big air pump. Use the vacuum guage to adjust idle mixture once it's timed with your timing light. Adjust idle mixture to acheive the highest vacuum level you can get. It'll be a little rich at this point. Also adjust idle speed to the proper setting and check vacuum again. It gives a good reference on engine condition.
Old Jan 30, 2007 | 11:31 PM
Torque1st's Avatar
Torque1st
Posting Legend
Use a timing light. If you adjust with a vac gage you will end up way off on timing.
Old Jan 31, 2007 | 05:25 AM
scottie2hottie's Avatar
scottie2hottie
agree with all said above, clean off your balancer and get a timing light from someone, you'll be glad you did.
Old Jan 31, 2007 | 12:55 PM
Gorilla1's Avatar
Gorilla1
Maybe my brother in law ain't as smart as I thinks he is! I'll get under and clean off the balancer again and mark it with paint this time. Tried chalk before but was still hard to read. Next question, where do I set it at? My manual says to go by the truck specs. Sadly the sticker with timing info has departed this earth and is no longer with us...
Old Jan 31, 2007 | 01:24 PM
tjc transport's Avatar
tjc transport
i ain't rite
i normaly advance the timing till i get pinging on an at temp engine, then back it off a tad and try it again, backing off till the pinging goes away. then i shut it off and make sure it starts up with no problem, and leave the timing that way. most of my vehicles have not had timing marks in so long that there is no way to do it with a light anyway.
Old Jan 31, 2007 | 02:23 PM
Mil1ion's Avatar
Mil1ion
Had you mentioned what year and model of truck
Engine, transmission, axle state of operation.
you would have known the specs on this post.
Old Jan 31, 2007 | 04:01 PM
Gorilla1's Avatar
Gorilla1
It's a '77 F150 351M 4WD shortbed, not sure what the axle ratios are, can't find the tag to read them. Haven't scraped off enough dirt and grease and mud yet to. Plus I'm afraid all that gunk is keeping it from leaking worse than it is. Engine's been rebuilt a little over a year ago, but I never got the timing right. It's dang close, but need to tweek it a smidge more. I did it by ear after I tried it with the cheap light I bought. Worked better even though my wife says I can't hear Gets horrid gas mileage but is a beast up in the mountains out here. Just may have to go again this weekend and uhh get firewood...
Old Jan 31, 2007 | 06:24 PM
Mil1ion's Avatar
Mil1ion
Trans ?
AT or MT ?
Calif or 49 state ?
Old Jan 31, 2007 | 11:17 PM
spide4x4's Avatar
spide4x4
A good way to read timing marks that are hard to see.....Baby Powder
Old Feb 1, 2007 | 01:05 AM
Mil1ion's Avatar
Mil1ion
I put "White-out" on my timing marks.
It seems to stick to anything
Old Feb 1, 2007 | 02:36 PM
Gorilla1's Avatar
Gorilla1
4 speed manuel. I would guess by California or 49 state, you're referencing emissions. Now that's funny! I imagine brand new it had emisions on it, but that old truck is more junk yard dog than anything now.
Old Feb 1, 2007 | 03:16 PM
thelonerangerxlt's Avatar
thelonerangerxlt
quote:
"Next question, where do I set it at?"
I'd guess the stock setting was 6* btdc. Anyway, I'd start at 6*, then if it dosen't ping, go up to 8*, then maybe 10*.
A good starting point on the carb idle mixture screws is 2 1/4 turns out. Then set them for the best vacuum, and then turn back in 1/4 turn. This will lean the idle slightly; should be about right.....
Old Feb 1, 2007 | 03:35 PM
Mil1ion's Avatar
Mil1ion
calibration code
7-71-R10
http://mil1ion.clubfte.com/78Calibra...e-upSpecs.html
choke 2 rich
curb idle - 650 rpm
Timing setting - 6* BTDC @ 650 rpm vacuum advance disconnected and hose plugged.
