Sponsored by: Auxito
Changing 2WD ball joints?
Old Jan 14, 2006 | 09:22 AM
banjopicker66's Avatar
banjopicker66
Is there anything special about changing upper ball joints on my '98 F-150 2wd? Are they just the usual type, press in and press out?
Old Jan 14, 2006 | 11:17 AM
BuiltFordTOugh4Ever's Avatar
BuiltFordTOugh4Ever
When should I change the ball joints on 2WD 02 F150?
Old Jan 14, 2006 | 06:05 PM
ford390gashog's Avatar
ford390gashog
yes they are that type.
Old Jan 15, 2006 | 08:24 AM
projectSHO89's Avatar
projectSHO89
Uh, NO, they're not unless..
Replace the whole upper control arm that includes the ball joint unless it has been previously replaced with an aftermarket one that feature removable balljoints. Moog supplies that style. Haven't seen any others.
Ball joints should be replaced when there is play in them greater than the allowable limit. No set mileage. Lower ones may wear out in as little as 35-40K.
Steve
