The last time I changed my oil I did it myself because the oil change place I used went up to 80 for an oil change from 70. I paid about 50 or so for the oil and filter (rotella). This time I was going to do it myself and the oil and filter were going to cost a little over 70, so I decided to take it back to the oil change place. They have gone up to 110 so I said F-it and decided to do it myself. While standing in walmart trying to figure if it would be cheaper to buy gallons or just get the 2.5 gallon size of rotella, I noticed the motocraft oil. It was alot cheaper than the rotella and it comes in 5 qt jugs so you can get an exact number to get the 15qts. Did I make a mistake useing the motocraft? Is it any good?
I never seen the 5 quart Motorcraft 15-40 diesel oil in my local stores either, your good to go. Synthetic Rotella and now Shaeffers for me. If it works for you, your good.
Yes, WM is selling 5 qts of Motorcraft dino 15W-40 Diesel oil for $11 & change. I mentioned that to one of the oil gurus here a while back and he said the truck might run a bit worse with it. Something to do with it foaming too much. Which surprises me -- I'd like to hear your results with it. That would be a dino OC for $44 + tax, including filter...
EDIT: I'd wouldn't mind seeing a Blackstone report on it after 5k miles, too...
I try to not run more than 3k between changes, so hopefully there wont be a way to get a report at 5k
I use it when it warms up a bit. changing to Rotella 10-30 for winter.
but YES walmart carries the 5q bottles. sure is handy when it comes to filling up the oil.
I have never had any trouble with Motorcraft. I acutally switch back adn forth to Rotella and Motorcraft. but I use a WIX filter cause the last motor craft from walmart didnt' fit on install.
