yes E4OD problems again!!
Old Jul 29, 2011 | 11:09 PM
blitzkrieg469's Avatar
blitzkrieg469
ok...just installed a different tranny in my 93 F-350 5.8. It has been running and shifting great for a week. Today I hauled and empty stock trailer with a 4x5 round bail in the bed and now it shifts hard (sometimes) and shifts too soon (and doesn't like to kick down very well either). Going to try to do self test tomorrow to get any codes (is there a way of clearing codes doing a self test?) The tranny is supposed to have been rebuilt and not have a lot of miles on it. It has fresh fluid, but I did not change the filter. ( I have a new one if you think it will help.Any ideas?
Old Jul 30, 2011 | 01:31 AM
Encho's Avatar
Encho
The Southernmost Mod
Have you checked that the tranny has enough fluid since the rebuild? mine was lacking almost 2qts. and it started acting up.
Old Jul 30, 2011 | 02:34 AM
fastbmw01's Avatar
fastbmw01
My E4OD was doing the same crap, and I changed the Speed Sensor at the Differential, and it now shifts perfect!
Old Jul 30, 2011 | 04:50 AM
86F150302's Avatar
86F150302
Could be mlps,rabs,or tps.
Old Jul 30, 2011 | 06:42 AM
blitzkrieg469
Fluid is full....tps vss mlps are new because of problemswith last tranny not shifting right...rabs is same and i dont remember where it is located
Old Jul 30, 2011 | 06:59 AM
Lazy K's Avatar
Lazy K
I think I would check for trouble codes, may help to pinpoint the problem.
You can clear any codes in two ways. You can disconnect the neg battery terminal for about 5min or, after you have read any/all codes and while the computer is blinking out the codes again, if you disconnect the ground wire from the STI connector, the codes should clear (as I understand it).
Old Jul 30, 2011 | 07:56 AM
rla2005's Avatar
rla2005
100% correct, sir! And this is the preferred method.
Old Jul 30, 2011 | 09:02 AM
blitzkrieg469
Thanks for the replies....but while under the truck checking to see if mlps had shifted i noticed a wire that po tapped into to run over to ground on the mlps plug had come loose from the plug(yellow wire)....i took off the extra wire and butt spliced it back to the plug....shifts fine now...(good thing have to take horse to fair today....lol)....will be buying a new plug tho...wire at plug was very short...hopefully butt splice stays on for a bit....thanx again people...love this forum
Old Jul 30, 2011 | 11:59 AM
Lazy K's Avatar
Lazy K
Great to hear that you found the problem.
And thanks to rla for confirming the code erase method.
bfwill
1978 - 1996 Big Bronco
Sep 13, 2009 11:38 AM
kevind95
Jan 5, 2009 12:13 PM
ZonaNavyStar
Jan 26, 2007 10:59 AM
ty77
Oct 31, 2003 12:19 PM
Thom_James4991
May 15, 2003 09:39 PM
