Broken Anchor Pin
Old Nov 1, 2010 | 07:33 PM
dell's Avatar
dell
Broken Anchor Pin
I'm replacing the rear brakes on my 04 Ranger FX 4 with a 4.0 engine. The old brakes and drums were absolutely shot. While trying to remove the shoes and springs the anchor pin at the top broke off, flush. I was wondering if any one else has ever had this problem, if so what's the best way to get the rest of the old pin out? Does any one know the size of the pin?I know I'll have to go to a dealership to get a new anchor pin, but I don't know what all's is going to be involved in getting the old one thing out? Any help would be greatly appreciated. Thanks
Old Nov 1, 2010 | 07:44 PM
reddog99's Avatar
reddog99
Sorry I can't help you, but I'm curious. How many miles has it taken to wear out the rear brakes?
Old Nov 1, 2010 | 08:36 PM
cj06's Avatar
cj06
that pin should bolt on , look on the back for a nut ! never have broken them off .
Old Nov 2, 2010 | 12:21 PM
dell's Avatar
dell
Not sure right off hand, but I know it's not enough to wear out the rear brakes like it did. I've only had the truck for about a year. It must of had some hard driven highway miles on it? I only drive to and from work it's about a 10 mile round trip.
Old Nov 2, 2010 | 12:28 PM
dell's Avatar
dell
Yes, the dealership said that it should thread off and the nut on the back may only be tacked on and should tap off. My problem might be that before I found that out, I drilled it out and tried to use an easy out on it. Lets hope the bolt doesn't snap off trying to unthread the thing.
Old Nov 2, 2010 | 02:49 PM
cj06's Avatar
cj06
you might want to pull the backing plate off and put it up on the bench where it would make it easier to get at !
Old Mar 8, 2017 | 11:15 PM
RangerRuss's Avatar
RangerRuss
changed rear brakes for first time at 204,530 miles
Steve in NC
Jul 21, 2022 07:43 PM
F-250 WARHORSE
15
Feb 12, 2021 02:00 AM
191124x7
All Things Towing
15
Apr 16, 2017 02:51 PM
BjornF16
Nov 18, 2016 03:17 PM
IIGood
Feb 29, 2016 08:30 PM
