Strange Fuel Pump Problem
Old Jul 29, 2011 | 10:23 AM
JoeHarbourJets's Avatar
JoeHarbourJets
According to the block stamp, my F100's engine is from a 75 Econoline. It's a 300 6 cyl. When I got it I ditched the fuel pump and lines, knowing they were clogged with rust and crap from the old tank. Since then I've installed two new pumps, both of which give me the same trouble. They simply pump very little. Not much more than a dribble into the filter, and of course the carb starves. I've ruled out filters and lines as a possible source. Today for the hell of it I tested both pumps just by cranking the lever by hand, and they both shot gas like crazy. Just won't do it on the engine. Any ideas?
Old Jul 29, 2011 | 10:30 AM
co425's Avatar
co425
Chunks of crap in your carbs inlet? Or the same in your float needle seats.
Old Jul 29, 2011 | 10:39 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
The sock/filter on the end of your pickup tube in tank is more than likely clogged.
Old Jul 29, 2011 | 10:40 AM
mark a.'s Avatar
mark a.
Put the feed line into a can of gas and see how it acts, that will tell you if you have a problem from the pump back to the tank.
Old Jul 29, 2011 | 11:49 AM
mikeo0o0o0's Avatar
mikeo0o0o0
X2 on the "sock" filter in the tank. A less likely problem is a worn camshaft lobe.
Old Aug 8, 2011 | 11:20 AM
JoeHarbourJets
Having (I think) eliminated all other possible sources of the problem, such as lines, filters, I have it down to 2 possibilities: a worn cam lobe or the wrong fuel pump. I notice in looking at the parts online that the fuel pump for the '74 version of my engine has a straight arm, while the new one I have for my engine (which the ID stamp says is a '75) has the bent arm. The straight arm would mean a lot more contact with the lobe. The one I have, with the bent arm, has very little contact with the lobe, based on the wear on the finish of the arm and the amount of fuel pressure it's putting out. I wonder if it's possible my engine takes the '74 pump? Anyone every encounter this before? The pump that was in there, when I got the truck, might have given me a clue, but like a damn fool I threw it away along with the old lines when I took them out.
jnolan
Aug 2, 2019 08:05 AM
StanJo
13
Jun 12, 2014 07:46 AM
jwilly53
May 6, 2012 05:30 PM
Myfreeford
Jul 13, 2011 06:05 PM
rusty 58
Dec 8, 2000 10:35 PM
