Sponsored by: Real Truck
Dead Fuel Gauge
Old Jul 28, 2011 | 05:40 PM
Desert 4x4's Avatar
Desert 4x4
Dead Fuel Gauge
The fuel gauge on my 04 F250 5.4 has died a second time. The first time the Dealer fix the problem because it was under warranty. This time around I have to fix it myself. It seems the fuel sending is the problem. The gauge dies and the low fuel light comes on, a short time later the check engine light comes on. How do I go about replacing the sending unit?
Thanks Desert 4X4
Old Jul 28, 2011 | 07:22 PM
Pili's Avatar
Pili
First get the code checked. Odds are its a bad ground but if it is the sending unit. Empty the tank as much as possible then disconnect the battery, lower the tank (with a floor jack) enough to get your arm above it and unplug all the connectors, lower the tank the rest of the way. You will need a sharpie, brass punch and a hammer. with the sharpie draw a line where the sending unit is clocked. Take the punch and hammer and tap the retaining ring counter clockwise and pull the sending unit out. Put the new unit in as the same position as the old on and do everything else in reverse order.
Its a fairly easy job will take you maybe an hour. If your not very mechanically inclined while your at the parts store getting the sending unit pick up a service manual it will have step by step instructions with pictures
Old Jul 29, 2011 | 03:35 AM
Desert 4x4's Avatar
Desert 4x4
thanks pili
Old Aug 11, 2011 | 03:26 PM
Desert 4x4's Avatar
Desert 4x4
Fixed the sending unit. There is one wire coming off the sending unit that broke right at the solder joint. I could of resolder the wire but, I had a new sending unit ready. I can use the old one as a spare.
Does anyone know the size of the rubber gas line coming off the gas tank. The line is at the front and rear of the tank and appear to go to the vapor canister.
elroy6468
May 13, 2015 04:23 PM
btracy
18
Jan 14, 2013 09:47 AM
davewave649
Aug 22, 2012 03:27 AM
Aaron-71
Aug 19, 2010 05:41 PM
Hunt4Fun
Nov 12, 2008 03:07 PM
