This is strange. My wires for the light goes right into the wire horniest just above that connection you have. I don't have that connection.
Can someone else with an 01' look and see if you have what Robin posted?
Originally Posted by izzybird
No connector on the '00 or the '01. Straight into the wire horniest... I mean harness.
I'd have to look at mine to verify this, but IIRC Barney's '02 had a connector behind the hood insulation when we took it off. I'm thinking my '01 is the same since I haven't seen it. Makes me wonder. Always just remove the bulb too.
I didn't look behind the insulation for a plug. I have to wonder how you take the hood off without a plug there?
I just pulled the socket loose from the hood. It still hangs there but stays off since its tilted down enough. If I want light, I give it a little push up and the lights on. Easy to do and no plugs or bulbs to pull.
