Underhood light??
Old Jul 28, 2011 | 05:38 PM
pete/ny's Avatar
pete/ny
Underhood light??
I cannot figure this underhood light out at all! I replaced the bulb ( 912) and it still doesn't work.I checked the bulb socket with a test light and it lights up the test light. But bot the bulb.Any ideas why it still will not work.Thanks.
Old Jul 28, 2011 | 06:23 PM
Supercab's Avatar
Supercab
You might try gently pulling out the wire contacts on the bulb just a tad, and or using a small pipe cleaner to clean up the contacts in the socket......
Old Jul 28, 2011 | 06:41 PM
ToMang07's Avatar
ToMang07
Yeah, mine won't work, either.
Old Jul 28, 2011 | 06:49 PM
Shake-N-Bake's Avatar
Shake-N-Bake
I think my truck uses a 194 bulb in that socket...(going from memory though..)
Old Jul 28, 2011 | 07:34 PM
whitesdford's Avatar
whitesdford
This may sound goofy, but I replaced the bulb and the holder. I ended up putting the holder in upside down, and the light would come on when I shut the hood, instead of coming on when I raised it.....
Old Jul 28, 2011 | 09:02 PM
guitarpicr's Avatar
guitarpicr
Don't they turn off automatically after so many minutes? Seems like mine did that but not sure.
Old Jul 28, 2011 | 09:42 PM
PaysonPSD's Avatar
PaysonPSD
The bulb socket also contains a mercury switch. The mercury flows back and forth to close or open the circuit as you raise and lower the hood. That is why whitesford's bulb would come on when closed and go out when open when it was put in backward.
You can see the light come on as you raise the hood and go out as you close it so it is not on a timer.
Old Jul 29, 2011 | 07:00 AM
Krazymaan's Avatar
Krazymaan
Yep, its a mercury switch. If the light is on and its a mercury switch it might have a timer somewhere in the system just like the dome. It can be a mercury switch and a timer at the same time.
Old Jul 29, 2011 | 07:06 AM
Supercab's Avatar
Supercab
The use the same bulb as many of the Ford 3rd brake lights. Any luck yet??
Old Jul 29, 2011 | 07:18 AM
Rose Clifford's Avatar
Rose Clifford
fyi mine goes off after a couple minutes when the dome light does
Old Jul 29, 2011 | 08:00 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
If I leave my hood open, the light stays on as long as the hood is open.
Old Jul 29, 2011 | 08:28 AM
Supercab's Avatar
Supercab
Wink
+2 I slip the bulb out of mine if I'm going to have the hood open for a long period of time.
Old Jul 29, 2011 | 08:47 AM
miller_feed
I do the same.
Old Jul 29, 2011 | 09:27 AM
PaysonPSD's Avatar
PaysonPSD
That's what mine does.
I pulled the connector near the firewall and only connect it if I want the light on, which is like never.
Old Jul 29, 2011 | 10:31 AM
miller_feed
I need to find that connector.
