Underhood light??
Old Jul 29, 2011 | 11:38 AM
PaysonPSD's Avatar
PaysonPSD
Originally Posted by miller_feed
I need to find that connector.
Here you go Rick.
Right above the brake fluid reservoir. Shown connected, but I leave it disconnected.
Old Jul 29, 2011 | 11:45 AM
Shake-N-Bake's Avatar
Shake-N-Bake
I do the same.
Me three. All I have to do is move the bulb a little bit to one side in the socket and it turns off. I then leave it like that unless I need it for some reason. For the most part that light is practically worthless for my aging eyes. I have a big rechargeable LED drop light that I carry around with me and I prefer to use that because I can see so much better.
I've always wondered why Ford put the light on the left side of the engine bay. The crankcase and trans dipsticks are on the other side....
Old Jul 29, 2011 | 11:55 AM
PaysonPSD's Avatar
PaysonPSD
What side of a gasser are the dipsticks .
Why not pull the connector apart and leave it that way.
It's easy enough to reconnect if you really need that puny little light.
Old Jul 29, 2011 | 12:42 PM
Supercab's Avatar
Supercab
The light is fine for me to just check fluids if need be on the road in the dark, which isn't often...
Old Jul 29, 2011 | 01:45 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Originally Posted by PaysonPSD
Here you go Rick.
Thanks Robin. I just never looked for it. Easy enough. lol
Old Jul 29, 2011 | 02:01 PM
PaysonPSD's Avatar
PaysonPSD
I knew you could find it without help but a picture is worth a thousand words.
Old Jul 29, 2011 | 02:39 PM
miller_feed
I was hoping for a pic of me beating your time last year at RRE.
Old Jul 29, 2011 | 07:24 PM
pete/ny's Avatar
pete/ny
FIXED!
I got my light fixed today.I took the assembly off the tab on the hood and split it open.The contacts inside were GREEN with corrosion.I don't think ( at least in my 2002) that this light is control by mercury like the older ones were. In mine is a small silver metal canister and what souns like a small roller ball inside of it.When I cleaned up the assembly and hooked it up ( not on the tab yet) you could get the light to function by tilting this assemby one way or another. Seems that the ground end in the assemby was the worst and by me puting the test light on the + connection and grounding it on the hood, the light would lite up. Just thought I would pass this on as I called the dealer and he said this entire assembly was over $50~ it does light up the engine bay pretty well to just to check fluids if needed. Thanks again for the replies.
Old Jul 29, 2011 | 07:47 PM
guitarpicr's Avatar
guitarpicr
You can get a 12 volt light at an rv store for about 10.00 with a switch on it. Just mount it and turn it on when needed. They are nice & bright too. I put 2 of these in my work van for night time service calls
Old Jul 29, 2011 | 07:54 PM
pete/ny's Avatar
pete/ny
Pics?
Good idea. Have you a link to these lights or a pic of them for future reference? Thanks
Old Jul 29, 2011 | 07:58 PM
guitarpicr's Avatar
guitarpicr
Double Dome RV Light - PPL Motor Homes _ here ya go Pete- They come in single config also
Old Jul 29, 2011 | 08:04 PM
pete/ny's Avatar
pete/ny
Thank you.
These are nice and bright I am sure.
Old Jul 29, 2011 | 09:06 PM
  #28
PaysonPSD's Avatar
PaysonPSD
There's always next year Rick, but I'll be ready for you.
I suggest you put that dually on a diet. It's going to be like a sumo wrestler in a foot race with a wide receiver.
Old Jul 30, 2011 | 08:43 AM
  #29
miller_feed
Here you go Rick.
This is strange. My wires for the light goes right into the wire horniest just above that connection you have. I don't have that connection.
Can someone else with an 01' look and see if you have what Robin posted?
Old Jul 30, 2011 | 09:18 AM
  #30
izzybird's Avatar
izzybird
No connector on the '00 or the '01. Straight into the wire horniest... I mean harness.
