a/c clutch hub
Old Jul 28, 2011 | 12:31 PM
OSSKOBRET433's Avatar
OSSKOBRET433
a/c clutch hub
i read a post by springer pop on the gap at hub , found mine to be big , trying to get hub off and i cannot get bolt out ,tried to activate hub to break nut loose but hub keeps spinning . any ideas going to havasu tomarrow........... i need my air
Old Jul 28, 2011 | 05:18 PM
projectSHO89's Avatar
projectSHO89
https://www.ford-trucks.com/forums/6...ml#post5054687
A screwdriver will work, also. Otherwise, you can go to the auto parts store and rent/buy the clutch holding tool.
Old Aug 8, 2011 | 01:53 PM
VA250SD's Avatar
VA250SD
I had same problem. What I did was position a screwdriver so that it caught on one of the hard rubber discs on the clutch and a bolt on the engine nearby to stop rotation of the clutch. This allowed me to get enough torque on the center clutch bolt to loosen it.
Physics Outlaw
Aug 31, 2015 09:56 AM
sparrky81
Aug 15, 2009 07:52 PM
Capt.Schenk
Jul 1, 2009 12:10 PM
Pastmaster
Nov 1, 1999 09:40 PM
