a/c compressor problem
Old Jul 10, 2007 | 06:30 PM
andrewlee's Avatar
andrewlee
I have a 2002 f-350 power stroke diesel and the a/c compressor shuts off at low rpm, like when you exit the freeway. It runs fine at all other rpms, just not whent the rpms drop off to idle. Can any one tell me what the problem is?
Old Jul 10, 2007 | 11:57 PM
lsrx101's Avatar
lsrx101
How does the AC cool on the highway? At idle or low speeds? Does it quit cooling at idle or low speeds? Does the compressor eventually come back on?
Old Jul 11, 2007 | 06:42 AM
projectSHO89's Avatar
projectSHO89
Have you determined 100% that the clutch is disengaging as described?
Have you measured your clutch air gap? Tried hitting the clutch face with a mallet or broomstick while at idle to see if the clutch pulls in?
Steve
Old Jul 11, 2007 | 01:21 PM
andrewlee's Avatar
andrewlee
The a/c cools fine at highway speed and at low speed, just when you go from high rpm to low rpm the compressor shuts off. I haven tried checking the air gap yet.
Old Jul 15, 2007 | 01:31 AM
bustech81's Avatar
bustech81
so to clarify, clutch only disengages when you go from high rpm to idle. does the clutch re-engage right away or 30 seconds or a minute or what? does it cycle @ idle.
how does it cool at idle?more info please.
Old Jul 16, 2007 | 04:29 PM
lsrx101's Avatar
lsrx101
"The a/c cools fine at highway speed and at low speed, just when you go from high rpm to low rpm the compressor shuts off."
I'm starting to wonder if this isn't built into the clutch operating logic in the PCM for some reason. It seems to be cooling well, if I'm understanding things correctly.
How do you know the compressor is cutting out. Have you actually seen it, or does the vent temp go up when you decelerate, causing you to assume the compressor is cutting out.
Old Aug 18, 2007 | 03:01 PM
isaadidin's Avatar
isaadidin
I have same problem with 2001 f250. When engine starts, A/C cools just fine. After few minutes at low RPM it shuts off. I step on the gas for higher RPM, the A/C comes on fine for few minutes until the RPM start going down again.
When I hit the clutch with a broomstick the clutch re-engages and A/C starts cooling
Old Aug 18, 2007 | 05:56 PM
2000Ford2000's Avatar
2000Ford2000
That sounds like you have a loose connection to your coil. When you raise the RPM, you get higher voltage and higher amperage to 'jump' across a bad connection. You might be able to unplug and plug in the connection a few times and find that it fixes it.
Old Aug 18, 2007 | 07:12 PM
lsrx101's Avatar
lsrx101
That's caused by the clutch gap being too wide. Remove the center bolt, slip the clutch plate off and remove one of the shims between the plate and compressor shaft. You want less than .020".
Old Aug 22, 2007 | 11:57 PM
jdonline's Avatar
jdonline
Any news on figuring out what occured with your clutch. I'm interested in hearing how this problem was answered so I can have it for future reference when discussing this problem later on. Thanks!
JD
Old Aug 23, 2007 | 06:37 AM
nutfarmii's Avatar
nutfarmii
lsrx101, how do you get the clutch not to rotate while trying to get the 8mm bolt loosened? Do you need a special tool to hold it down or would a block of wood and a large c-clamp work?
Thanks
Marc
Old Aug 23, 2007 | 07:58 AM
projectSHO89
Thanks
Marc
I just use a long box wrench. Slip the box end over one of the "nubs", use my socket as a fulcrum, and let the arm of the wrench rest against something solid while loosening or tightening the bolt.
Steve
Old Aug 23, 2007 | 10:27 AM
ozzjob's Avatar
ozzjob
When I took my clutch plate off to remove the shim I turned the A/C switch on and turned the key on do not start the engine. That will hold the plate from moving while you loosen the center bolt. Then turn the the key off and take the clutch plate off. When you get ready to tighten the center bolt turn the key back on to keep the plate from moving.
Jim
Old Aug 23, 2007 | 08:05 PM
nutfarmii's Avatar
nutfarmii
Thanks to both Jim and Steve, got the clutch plate off and removed 1 shim retightened took her for a spin 2.5miles parked it and retightened the bolt took one more spin checked the bolt and its on tight and appear to have nice frosty air. Will update tomorrow afternoon when I get off work as the true test appears more when we hit 95+ degrees in the afternoon.
Appreciate everyone's input.
Marc
kountzecobra
Feb 22, 2016 08:38 AM
AggieOutlaw
May 19, 2015 02:26 PM
emueller
Jan 22, 2011 12:50 PM
Opossum
Nov 9, 2008 01:19 PM
T_Moss
Apr 25, 2006 07:29 PM
