Pig Headed
Old Mar 31, 2003 | 05:40 PM
Charlie's Truck's Avatar
Charlie's Truck
Pig Headed
In a past post I asked about putting a non computer engine/trans in my 1994 F-150. A 351 cleveland with a C-6.
Well I was told no computer no speedo.
Question #1 can a speedo from a older Ford work
Question #2 can a computer be fooled? if the sences are in place (o2 ,air flow. temp, anti knock throttle postion) I know nothing will happen cause it has a carb, but will the computer know, will the speedo work, the worse case the check engine light will come on If this would work what sences are on the trans.
Question #3 should I give up this dream buy a diff. truck ( This truck is in great shape,only 59000 on the clock some rust on the frame but thats it)
Thanks in advance!!!!!
Old Mar 31, 2003 | 06:25 PM
pfogle's Avatar
pfogle
Pig Headed
you could try to retro-fit an old cable style speedo to work with the mechanical tranny.
Old Mar 31, 2003 | 09:46 PM
steve83's Avatar
steve83
Pig Headed
Whoever told you that was wrong. The speedo does NOT go thru the engine computer - it's self-contained and requires only the rear axle sensor & power. Read this thread.
Old Apr 1, 2003 | 05:04 AM
Charlie's Truck
Pig Headed
Steve, thanks again, now wheres that credit card!!!!
elogan30
May 5, 2013 10:30 PM
2000MercMountaineer
13
Nov 19, 2011 02:23 PM
hayden01
Nov 28, 2008 12:39 AM
mshaud78XLT
Engine Swaps
Feb 6, 2005 11:33 PM
Busa01
3.8 & 4.2L V6
22
Mar 11, 2004 02:33 PM
