Transmission upgrades??
Old Jul 27, 2011 | 11:48 PM
1982_f150's Avatar
1982_f150
Hey guys, My first gears been hittin hard now for a while, and Clay from riffraff figures I should get a new valve body. What are some other week points in our 4r100s? I was planning on a shift kit and some sort of converter. I have future plans to add some mild power to her, injectors, chip, propane or water/meth.. The usual. I'm looking to spend up to 3000$ what do you guys suggest I do? Thanks
Grant
Old Jul 28, 2011 | 01:50 AM
SpringerPop's Avatar
SpringerPop
Hard-hitting, and erratic shifts, are a sign that you may have a sticky line pressure modulator valve.
It's caused by a steel valve wearing in an aluminum bore.
Sonnax has a fix for that. See:
Sleeve & Plunger, Line Pressure Modulator , AX4N / E4OD / 4R100 | Valve body kits | Bulkpart transmission parts
There's other things to do when you have it apart, as well.
Pop
Old Jul 29, 2011 | 11:22 PM
1982_f150's Avatar
1982_f150
hhmmm thanks ill look into that.. but what are the things i should beef up in my trans when i have it out??
FordYoungGun35
Oct 18, 2013 04:08 PM
Tim Young
Jul 30, 2011 06:40 AM
eric777
Nov 22, 2006 08:22 AM
probablecause
May 24, 2006 08:16 PM
gearloose
13
Sep 26, 2002 08:51 AM
