4R100 thoughts....
Old Jul 27, 2011 | 10:52 PM
tarditim's Avatar
tarditim
4R100 thoughts....
Just pulled apart and went thru my 4R100. everything looked good, put new oil pump and new torque converter. Before i put it in just want some thoughts. My original problem was slipping in all gears,at idle it would catch and drive.Led me to believe its a pressure problem. Any thoughts before i put this thing back in???
Old Jul 28, 2011 | 03:18 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Did you replace all the seals? What did the frictions look like?
Old Jul 28, 2011 | 06:11 AM
tarditim's Avatar
tarditim
Frictions and steels all looked new, no heat spots and very little wear. Which also lead me to think that it was the TC/pump. But i didnt tear down the sun planetary clutch packs.
Old Jul 28, 2011 | 06:13 AM
tarditim's Avatar
tarditim
Just more of a patch than a rebuild
Old Jul 28, 2011 | 02:29 PM
jk080's Avatar
jk080
Transmission Rebuilder
Its hard to tell if you will fix the problem or not, there should have been more diagnoses before you pulled the trans, pressure test, scanner info, etc.
Did the pump look bad? they rarely have problems unless the converter had a big failure.
Metal in pan?
Old Jul 28, 2011 | 09:55 PM
tarditim's Avatar
tarditim
was some bronzecooring in pan not a whole lot. i reaized after tht i should of pressure checked it but hind sight is 20 20. as for the scaner there were no tansmission related codes. as for symptom i wasdriving along road puled over and started goin again, after about 5 min it reved at idle and low throttle it was ok anything more and it would slip. this happened in all forward gears aswell as reverse. I know te old C6 and 727 trannies just never played with a new style like this. is there anything in the rear section of the tran that would cause slipping in al gears?
Old Jul 31, 2011 | 11:20 AM
tarditim's Avatar
tarditim
Decided to pull it all bck apart and go thru further. When i gotto the forwrd cluth drum I found the inner steel (with the fingers) had broken.
Courtney Williams
Feb 13, 2017 11:20 AM
waterboyschmidt
Apr 19, 2016 05:07 PM
caedo
Feb 21, 2016 01:18 PM
Fishin76
Apr 14, 2015 12:24 PM
egbertf
Modular V8 (4.6L, 5.4L)
Jul 11, 2010 07:54 PM
