Install my pyro, temp??
Old Jul 27, 2011 | 08:59 PM
Insley95's Avatar
Insley95
I finished my pyro install this evening, with my 60hp tow tune and the truck empty it reads 1100 degrees when you running it hard. Does that sound about right??
Old Jul 27, 2011 | 09:22 PM
VegasFordSD's Avatar
VegasFordSD
sounds about right... just try to keep it under 1200.
Old Jul 27, 2011 | 09:54 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Around town look for 4-800. 12 should be your max. even prolonged 1100 wont be good for your 7.3
Old Jul 28, 2011 | 08:58 AM
timmyboy76's Avatar
timmyboy76
the gauge reading temp throws me off too, when not loaded (9k), at the time, could not see how i would be able to keep temps down, when it seemed as though it ran hot, not being loaded..meaning, temps seemed high, for just getting on the pedal.
Old Jul 28, 2011 | 01:27 PM
CSIPSD's Avatar
CSIPSD
Incorrect...
International (the guys who build our motors) says that 1250* sustained PRE TURBO temps are the red line.
You can tow all day long at 1250* and not hurt a thing other then your mileage. Anything over 1250* is on your own accord.
Again, you will NOT hurt a thing at 1100*... NOTHING.
As for going over the 1250* limit that IH says... its kind of up to your own risk taking abilities...
If your running empty all day at 600-800* and someone wants to play, its going to take a long time to do damage going over the 1250* mark (remember what EGT stands for- EXHAUST GAS TEMP- not piston temp)...
If your towing heavy and running 1100* for a few hours, it will take far less time to get the piston temps up to or above the damage point...
Your watching EGT's to protect the pistons, and an EGT gauge is not checking the temp of the pistons, just the gases that are around it.
Old Jul 28, 2011 | 01:43 PM
PaysonPSD's Avatar
PaysonPSD
Nice Post Joe. Clear and concise. Reps to you.
The rep police must have been out for donuts. They got me 3 times earlier today, but not this time.
Old Jul 28, 2011 | 02:53 PM
snakedoc's Avatar
snakedoc
empty and the SC 1705 i cant get over 1100. i have not pulled a good load to see how it dose.
AdamG238
Jan 10, 2013 08:11 PM
rcorcich
Jan 14, 2010 03:50 PM
F350SD
Dec 5, 2006 10:35 AM
notsoswwuyd
May 9, 2005 04:19 PM
RobertJohn
Jan 16, 2005 09:38 PM
