Coolant Filter
Old Jul 28, 2011 | 09:49 PM
BLADE35's Avatar
BLADE35
I didnt like any of the kits they all reduce the return line down
I keept the return line the same size drilled the filter out to 3/8 hole and dumped it back in at the heater return line
but any filter setup is better than no coolant filter setup
heres my coolant filter setup notice I tyed in before the control valve
Old Jul 30, 2011 | 02:19 PM
KTC06F350's Avatar
KTC06F350
Thanks for the pics and set-up info on the coolant filter. Appreicate the information. I found the Restore/Rstore+. Had to have it ordered from a local fleet maintenance shop. No one else could get it(local parts stores). Also found out Zerex has a Cat EC-1 Approved ELC. So have that on order also thru Napa. Expensive stuff, but supposedly good for up to 600,000 miles. Don't believe I would go that long without changing or having it checked. That Restore stuff aint cheap either, but from what I have read, it works good. Thanks for all the help. Have a good one. Gettting started on it now.
Old Jul 30, 2011 | 02:44 PM
BLADE35's Avatar
BLADE35
that coolant in my sig is from oreilys 23.00 gal full strenght
same 600,000 just needs a additive at 300,000 mileas
I will change it out every 100,000 miles for good measure Will see how the coolant filters hold up
Old Jul 30, 2011 | 06:29 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Hey guys here are some filter #'s. I cut and pasted so I don't know who to thank:
COOLANT FILTERS
Fleetguard WF-2077
Baldwin B5134
John Deere RE11992
Caterpillar 9Y4528
Cummins 3300721
Wix 24070
NAPA 4070
AC-Delco WF-108
Fram PR3383
Donaldson P554685
Alliance (Freightliner) WF2077
CarQuest 89070
If a one inch shorter filter will help you with clearances a Napa # 4069 is available also.
thank you guys, excellent. the shop i went to replaced it by a Hasting WC8. it is not in your list but hope it is ok with it.
Old Aug 1, 2011 | 12:25 AM
Hawkdriver69's Avatar
Hawkdriver69
Forgive my ignorance, I am just curious why you have to use distilled water instead of tap water?
Old Aug 1, 2011 | 09:58 AM
Special Ed's Avatar
Special Ed
Minerals are harmful...reduced protection, reduced coolant life, increased maintenance, and premature repair. The quality of water that you use will determine the overall efficiency, reliability, and longevity of the cooling system.
Old Aug 1, 2011 | 11:47 AM
Rusty Axlerod
Not to get all "sciencey" but corrosion or rusting as it happens in your coolant system is an electrochemical process. Distilled water doesn't conduct electricity very well so it inhibits corrosion. Adding minerals, oxides, and salts (like tap water) make it a good conductor, which promotes corrosion. Most people don't realize pure water (h2o) is an insulator.
Justin Jones
Apr 20, 2016 03:16 PM
DavidE
Jul 16, 2014 01:03 AM
rocky1074
Sep 25, 2009 12:48 PM
Benjoman
Sep 3, 2009 10:51 PM
Hamberger
Feb 3, 2006 11:40 PM
