Coolant Filter
Old Sep 2, 2009 | 10:49 PM
Benjoman's Avatar
Benjoman
Coolant Filter
I am getting ready to flush my cooling system and change over to Extended Life Coolant (EFC). In researching this I came across the Diesel Site Coolant Filter and I'm considering adding it to my EX. Has anyone installed one? It is supposed to fit behind the radiator and fan housing and in front of the alternator, but that space looks awfully tight on my '03 PSD.
Ben
Old Sep 2, 2009 | 10:58 PM
Stewart_H's Avatar
Stewart_H
Ben, I have one on 2000 Ex and it is a tight fit.
After buying it though, it came to my attention that a lot of what the coolant filter removes from the fluid is SCA fallout from the green coolant.
I have a 2002 F250 with the Gold coolant and I'm going to backflush that stuff out and refill with Chevron Delo ELC (like I did with my Ex) but I won't be adding the coolant filter on my 250.
After reading quite a few threads and posts on this over the three years since I've done the coolant filter install on my Ex, I'm just not convinced it's needed on rigs that have the Gold, or rigs that have been switched over to an ELC.
Truth be told, I'll probably take my setup off.
Stewart
Old Sep 2, 2009 | 11:17 PM
Benjoman's Avatar
Benjoman
Stewart
Thanks for the info. Yeah, saw that stuff about SCA also. Have you ever cut open a filter to see what its trapped?
Ben
Old Sep 2, 2009 | 11:19 PM
Stewart_H's Avatar
Stewart_H
Originally Posted by Benjoman
Stewart
Ben
LOL, its funny you ask that!
I have a filter sitting on my bench waiting for my procrastinating butt to do just that!
Stewart
Old Sep 2, 2009 | 11:23 PM
Benjoman's Avatar
Benjoman
let me know how it comes out. I just notice your byline. I might add never cook popcorn either.
Ben
Old Sep 3, 2009 | 08:44 PM
X-Hibition's Avatar
X-Hibition
The primary reason I'll be adding a coolant filter is to get the casting sand and general gunk out of the cooling system and hopefully extend the life of the water pump. It seems to be good enough for over the road diesels to have coolant filters. And the Diesel Site trans filter is looking good too.
Old Sep 3, 2009 | 10:51 PM
Stewart_H's Avatar
Stewart_H
I'm not convinced there is casting sand to filter out.
The older 7.3L PSD's that used the green coolant needed to have their SCA levels checked and when needed, additive was added to the coolant. I believe it's this SCA additive fallout that is being filtered out by the coolant filter.
Newer trucks that came with the gold coolant from the factory don't have SCA fallout because the gold doesn't require any additional additive.
As for the long haul diesel truckers, for the amount of abuse, engine run time, and just all around heavy duty wear and tear they put the engine through they probably need the coolant filter.
Stewart
bizzj
Dec 13, 2014 02:45 PM
barnhartred
Jan 17, 2014 01:41 PM
paulkcbulm
Jul 22, 2011 09:21 AM
Headviking
May 21, 2010 06:05 PM
mjtpolice76
69
Jan 15, 2006 01:43 AM
