Sponsored by: Real Truck
Dana 50 help please
Old Jul 27, 2011 | 05:41 AM
SSG W's Avatar
SSG W
Dana 50 help please
I've got the right side tore down replacing bearing and seals. There is a ton of sand gooped up in the axle tube. I've seen the home made "rake" but its not very effective. Any ideas on cleaning it out?? I thought about draining the diff and flushing tube with degreaser but am apprehensive about contaminating diff itself.
Old Jul 28, 2011 | 08:13 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
If it were me, I'd pull the front cover and make sure nothing made it into there anyway.
Then, I'd remove the carrier, and HOSE (yes, water and soap/spray degreaser) the tube out.
That much sand is not a good thing. It could have taken the oil seal out that's deep inside the tube, water got in, who knows. Either way, the only real way to clean all that stuff out is to use pressure from inside the carrier housing.
Bob T
Aug 13, 2011 05:50 AM
Justsam
May 6, 2005 06:45 PM
AKFord
Jun 13, 2004 11:47 PM
r.j.murphy
Mar 26, 2003 03:23 PM
redeye rye
Mar 14, 2003 03:12 PM
