ICP no start?
Old Jul 26, 2011 | 09:17 PM
mohle's Avatar
mohle
ICP no start?
Still working on my intermittent no hard/no start. Got the truck hooked up to a Ford IDS unit right now and was able to duplicate it after a few tries. Only difference I'm seeing is the ICP not jumping during cranking. IPR is good. So, will a faulty ICP sensor cause a no start? If so, can you bypass it by unplugging it and make the truck go into a default strategy?
Old Jul 26, 2011 | 09:24 PM
BLADE35's Avatar
BLADE35
yes unplug the ICP truck will use a default stratigy
also check IPR
mine runs at hot idel
640 ICP
22.5% IPR
if the IPR is like 30% or more at hot Idel you have a HPO leak
It must be checked while HOT like 190 ECT
Its got to running smoother since you got that plastic peice out of the injector???
Old Jul 26, 2011 | 09:54 PM
mohle's Avatar
mohle
also check IPR
640 ICP
22.5% IPR
It sure does run smoother. Attribute that to redoing the injector o-rings and the removal of unknown foreign object. OK, I did 3 different captures. IPR is 26.17% at idle (hot) pretty much on all 3. Icp is 4.60 MPa (667 psi) @ 0.91 v.
Cranking IPR 84.76% peak, ICP peak 15.62 MPa (2265 psi) @ 2.16 v.
When I was able to duplicate it, ICP dropped way down. While IPR was 20.05.
Old Jul 28, 2011 | 09:54 PM
mohle's Avatar
mohle
Ok, new ICP installed. Still cranks too much and has me worried that it will let me down again. Anyone have any thoughts on the readings? New ICP, new batteries, newer alternator, new injector o-rings, new IPR, newer STC etc....
Old Jul 28, 2011 | 10:25 PM
BLADE35's Avatar
BLADE35
did you do anything with the standpipes and dummy plugs when you reringed the injectors
Its best to take ICP and IPR readings at hot idel 190 ect its hard to tell anything during crank
I know I said 30% IPR at hot idel thats a pretty good leak though
I think 26.17% is getting up there
I know you can hook the IPR to 12 volts and close it while you blow air into the HPOS and listen for leaks
sucks to do it to a new IPR though but it may shed some light on it
could it still have air in it
Old Jul 28, 2011 | 10:46 PM
mohle's Avatar
mohle
Replaced the stand pipes. Not only would I hate to punish my new IPR, but taking it all apart again is painful
Old Jul 28, 2011 | 10:55 PM
mohle's Avatar
mohle
Besides, when she wouldn't start IPR was 20.05. Fuel pressure is also good. I'm starting to wonder if it isn't the FICM
Old Jul 28, 2011 | 10:57 PM
BLADE35's Avatar
BLADE35
I hear you on that one 12volts is alot for it
how about the dummy plugs in the HPOR on top the injectors
If you did those to Im running out of ideas theres only a pump left and I dont think its bad
good idea to check the ficm and maybe the egr valve
Old Jul 28, 2011 | 10:59 PM
mohle's Avatar
mohle
Might have just answered my won question there
corbin68
May 11, 2011 02:35 PM
bulla
Mar 9, 2011 03:36 PM
tbrewers
Aug 19, 2009 03:48 PM
CowboyUp1387
May 21, 2009 10:18 AM
powerstroked162
Oct 11, 2007 11:49 AM
