Bolt Pattern
Old Jul 26, 2011 | 03:53 PM
danlee's Avatar
danlee
Bolt Pattern
What is the distance between the two top bolts on a 400 motor bell/trans housing?
How about a Windsor motor?
How about a Diesel motor?
I'm thinking about buying an E4OD, but I need to confirm that it's a Big Block bell pattern.
Old Jul 26, 2011 | 04:48 PM
mark a.'s Avatar
mark a.
7 3/4" for the 351M/400 & 429/460. The width may be the same between the bb & sb, I'm sure the height is different between the 2. The 351M-460 bell housing is 17 7/8" top to bottom.
Old Jul 26, 2011 | 10:33 PM
85e150's Avatar
85e150
Pretty pics:
FordFE Forum Faqs
Old Jul 26, 2011 | 11:15 PM
ctubutis's Avatar
ctubutis
Originally Posted by 85e150six4mtod
Pretty pics:
FordFE Forum Faqs
I would rep you for submitting that page but have to spread the love.
Old Jul 27, 2011 | 04:50 AM
danlee's Avatar
danlee
Pretty pics:
FordFE Forum Faqs
Thanks, that will help. I'm sure that the 7.3 Diesel bell is larger yet. I don't have to worry about an FE pattern, because the E4OD was never used on an FE motor.
Old Jul 27, 2011 | 04:56 AM
ford390gashog's Avatar
ford390gashog
The 7.3 looks very close to a BB pattern!!! Its only about 3/8'' off and easy to mistake!! Just make sure the trans you look at has bolt holes in the trans for the starter if it does NOT then its a diesel trans as those mounted to an adapter plate. Thats the only quick way to tell them apart.
http://img812.imageshack.us/img812/2657/deiselzf5.jpg
Louisville Joe
13
Oct 8, 2010 02:00 PM
OH_VDUB
Apr 22, 2008 12:07 PM
straightsix4x4
Jan 29, 2008 10:45 AM
traveler2
Engine Swaps
Jan 18, 2005 10:56 AM
va hunter
Sep 11, 2003 11:20 AM
