Borg-Warner T19-148 ?
Old Jul 26, 2011 | 01:23 PM
Mtnplow's Avatar
Mtnplow
Unearthed my Trans and found this.....Is it a good trans, what problems,what fluid for the trans and transfer case and what is the electric connection on the back of this transfer case for ?
Sorry for all the questions but other than it's a 4-speed 4x4 with PTO Dump I don't know anything more. What kind of clutch/pressure plate setup is recommended.
Thanks again.
Old Jul 27, 2011 | 09:55 AM
Mtnplow's Avatar
Mtnplow
Bump need some info since I have access
Old Jul 30, 2011 | 06:02 PM
Ron/RPMS's Avatar
Ron/RPMS
That is a t-19 borg warner. Granny and syncro first. They have a close ratio and wide ratio but I think you will have to check 1st to know which one it is.Wide ratio has a 5.11 to 1 first , close has a 4.20( not sure) to 1 first.. Its regular 90w gear oil. ,not sure about the t-case, I have a bw t-case and it takes ATF.
The electrical connection at the back of the t-case is for a 4x4 indicator light.
Old Aug 3, 2011 | 03:15 PM
Mtnplow's Avatar
Mtnplow
Thank you, just got my Clutch kit today, it's beginning to go together.
Old Sep 14, 2011 | 07:32 PM
Mtnplow's Avatar
Mtnplow
so went to drain the box today and it was full of water and gear oil yeah !!! for shts & giggles I ran a magnet into the drain and it wasn't giggles, it was sht. I found a a large flat washer in pieces and 2 dif roller bearing rollers. So it's back together and put on the back burner. If it blows it blows, with all that torque and HP I think something down the road will go
Old Sep 17, 2011 | 03:48 PM
Ron/RPMS's Avatar
Ron/RPMS
Did you take off the PTO and look inside of it? PTO maybe torn up and the trans ok. Just a thought...................
p
pto
frank washington
Mar 9, 2017 01:53 PM
wbeam
Mar 20, 2013 07:49 PM
mrblonde108
Large Truck
Nov 15, 2011 06:05 PM
90vinG
Apr 5, 2011 08:55 AM
bishop0179
16
Mar 6, 2009 08:23 AM
