I recently replaced some rear brake lines and one wheel cylinder on my 88 f150 super cab. The brakes felt great for a week then started to get soft. I bled them again and they were good for a week again. I've done this 3 times.
They're getting air somewhere, Anybody have any ideas about if it's my fittings or the wheeel cylinder?
It sounds like your master cylinder is on its last legs. My f150 did the same thing. brakes would feel good then they got mushy. Kinda freaked me out the first time it happened. You might want to try bleeding the brakes again. Get a 1- 1 1/2 foot long piece of CLEAR 3/8 in diameter rubber tubing. put one end on the relief valve, and the other in a clear jar 1/4 full of brake fluid. make sure the end of the line is in the fluid. hope this helps ya.
i had the same problem on a taurus that came into the shop one day. we popped the hood and as it turns out, the owner must have lost the cap to the brake fluid reservior, so in their infinate wisdom replaced it with a piece of tinfoil and a rubber band.
i really doubt this has anything to do with your problem, but its just funny.
but the air in the brakes thing may be your proportioning valve. i know when they start to go bad, you get similar symptoms.
I pulled much hair out a month ago over same condition. Replaced rear wheel cylinders and pads and brakes needed to be bled every couple of days after that. I finally found the problem at the master cylinder. Have someone put a lot of pressure on the brake pedal and feel for fluid eveywhere there is a fitting. Mine was leaking at the rear brake line coming out of the master cylinder. Just a small leak under hard pressure. I guess when I let off the brake it would suck air in there. Tightened the #$%$@ out of that line and it was fixed. It must be a very small leak in the system.
sounds like your sucking in air somewhere prob like that one guy said when braking hard, prolly a slight leak at fitting or pinhole in the line. Maybe even a over flexed rubber flex hose, but that would mean the brakes would always be spongy and not just after a couple weeks. The replacement wheel cylinders are also pretty cheap and poorly made and may be faulty from the factory. Worst case scenario its your master cylinder thats leaking or shot, or abs hydra. unit is leaking or shot . If you didnt already bleed the front brakes first then bleed at the abs unit(if equipped) and then the rear just to be sure of no trapped air in the line. For all you out there use two people when bleeding and start with the wheel closest to master cylinder first and thereon.booooya
S.N could also be a bad seal on master cylinder cap.
Holy **** I really need to start looking at the post dates
