long cranking to start
Old Jul 25, 2011 | 07:50 PM
fishmanndotcom's Avatar
fishmanndotcom
if its no one thing its another. ok after pulling my fuel bowl recently i have a long crank issue. HPOP is full and oil is clean. fuel bowl is full of fuel. no fuel or oil in valley. no leaks i can see (and i have been doing a lot of looking lately). is their something in the FPR i prolly screwed up and allows fuel to drain back down?
thanks as always
-cutts-
Old Jul 25, 2011 | 07:59 PM
Krisx125's Avatar
Krisx125
I have the same issue all of a sudden...Takes a good 10 seconds to start
Old Jul 25, 2011 | 08:08 PM
fishmanndotcom
exactly my symptom!
BTW... my FPR screen was CLOGGED. cleaned it and put it back together. forgot to mention that
-cutts-
Old Jul 26, 2011 | 06:32 AM
fishmanndotcom
does anyone have a pic or diagram of how the FPR parts are put together? i am wondering if i lost a part or didnt put it back together properly
-cutts-
Old Jul 26, 2011 | 01:07 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
-cutts-
Maybe this helps you a little (its from an early model)
http://rides.webshots.com/album/76824672MwFOuc
I have more pics in another PC if you want let me know and later I can post here.
Old Jul 29, 2011 | 06:25 AM
fishmanndotcom
thanks a bunch man. i took my fuel bowl back out last night after receving my package of o-rings. i re-sealed the bowl and got it cleaned up. i also took the FPR back apart. i really dont think i messed up the installation but i re-o-ringed it and cleaned it up as well. put it all back together and tried again. she still takes 10 seconds or so to start up. i am wondering if i messed up the FPR screen assembly somehow. either that or there is air in the fuel system now and i need to just run the truck and bleed the air off. this would make sense bc it only started after i took the fuel bowl off initially.
any other ideas?
-cutts-
Old Jul 31, 2011 | 05:44 PM
fishmanndotcom
ok i drove the truck this weekend consecutively 15 miles or so (still with the oil leak and wiring issue) and the cranking seems to be getting better so i think i just need to work out the air. i just scared myself thinking i did something wrong.
NOOOOWWWWW it seems i have a fuel leak, lol. it just wont stop for me lately. i know it is coming from the large banjo bolt on the back of the fuel pump. not sure is there an o-ring or does it just need to be tightened? i havent had the patience to go work on it yet.
-cuttsj-
Old Aug 1, 2011 | 09:06 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
-cuttsj-
It has two washers, maybe with thightening it you solve you issue. good luck. If not possible the fuel pump or fuel hoses.
Old Aug 1, 2011 | 10:38 AM
DIYMechanic's Avatar
DIYMechanic
Like Jose says, no o-rings (one of the few things on this engine that does not use o-rings) just two brass washers. Not really a big deal to try to tighten it. Everybody has their own way of doing it with a different tool, but I just use an 1 1/4" combination wrench. Clearance is a bit tight, but it can be done with everything in place. Mine was seeping a bit again the other day, so I gave it a 1/4 turn and it seems to have stopped for now. Next time it's getting a new fuel pump, and new fuel hoses.
Bear in mind that the banjo bolt may very well be leaking, but it is also a possibility that your leak is coming from the pump itself, and it may be on its way out.
Old Aug 1, 2011 | 09:42 PM
fishmanndotcom
thanks guys... i had typed up a post earlier today but apparently i go tbusy and forgot to submit it.
thanks for the help. i tightened the banjo bolt another 1/8 of a turn and so far so good. i will have to see in the long run.
-cutts-
jspence105
22
Feb 2, 2016 02:17 PM
mpbpulaski
Feb 16, 2012 03:56 PM
snaponprofile
Feb 2, 2011 07:54 PM
Pitchfork87
Sep 7, 2009 08:36 PM
IceboxFX
Nov 21, 2008 05:10 PM
