Soda vs Sand blasting
Old Jul 25, 2011 | 04:28 PM
oneill's Avatar
oneill
I want to send my 53 F100 out to be blasted. Can someone recomend a place in So.Cal? Can someone explain the difference as far as which works better?
Old Jul 26, 2011 | 04:12 PM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Soda will remove paint only. Sand will remove rust, body filler but needs done by someone knowing not to overheat the metal.
Old Jul 31, 2011 | 01:31 AM
Chaosracing's Avatar
Chaosracing
Soda only removes paint, and if not cleaned up really good, can cause damage further down the road (if its in seams and gets wet it will blow apart the seam like rust does) Sand blasting gets rid of paint, rust, bondo but can also warp the steel.....no matter how careful you are with it. See if you can find someone that Media Blasts. They use all kinds of stuff....ground up walnut shells, plastic beads and now I have seen some using coal dust as well. It wont warp the steel, but should remove everything. Heavy rust might remain in some spots, but thats easy to fix.
zoomer
Jun 11, 2009 02:02 PM
MBDiagMan
Paint & Bodywork
17
Sep 29, 2007 08:08 PM
godblessmud
Paint & Bodywork
Sep 27, 2007 02:47 PM
Boss_358
Paint & Bodywork
Aug 18, 2002 08:20 PM
