If you want to trouble shoot you're psd you need real time capability as codes dump rather quickly and some things don't set codes at all just data to be interperatedthe AE ford bundle is the best bang for your buck as you can add other mfgs if you should ever need and it is not just a scanner, it is a full diagnostic instrument with real time data!
Jim...& fat Monty
The thing is the PSD trucks are not OBDII compliant, they are diesels and do no have to be.
Again, a GENERIC OBDII Scanner WILL NOT read most of the codes/systems on a PSD.
A regular SD gas engine it should be fine tho, although I have never owned one and never tried. Keep in mind they want to sell you a product, just because it will plug into the OBDII port does not mean any OBDII scanner will work. Changed real quick to make a point!
I ended up getting a AutoEnginuity Total Ford Enhanced Bundle from strictly diesel. RiffRaff is on vacation for a bit and shipping is delayed.
